CONTROLING LED and Sent Data Sensor VIA BLUETOOTH
Excusse me…
PLAN MY WORK >> I want to controlling LED in slave Bluetooth from PushButton Master Bluetooth. Then there are Sensor Data on a Slave Bluetooth that will be sent to a master.
PROBLEM >> My LED can’t turn ON. but My signal form Master it has been received by slave.
This My Code for that [SLAVE PROGRAM]
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(10, 11);
boolean DEBUG = true;
#define ledPin1 2
#define ledPin2 3
#define ledPin3 4
// Variables used for incoming data
const byte maxDataLength = 20;
char receivedChars[21] ;
boolean newData = false;
int jarak1, jarak2, jarak3, jarak4; // 4 sensor DISTANCE
double y1 = 0, x1 = 0, y1_1= 0, y2 = 0, x2 = 0, y2_1= 0;
double  y3 = 0, x3 = 0, y3_1 = 0, y4 = 0, x4 = 0, y4_1= 0;
const double a = 0.1;
  pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  pinMode(ledPin3, OUTPUT);
  digitalWrite(ledPin1, LOW);
  digitalWrite(ledPin2, LOW);
  digitalWrite(ledPin3, LOW);
    if (DEBUG)
        // open serial communication for debugging
        Serial.println(__FILE__);
        Serial.println(" ");
    //  open a software serial connection to the Bluetooth module.
    BTSerial.begin(38400);
    if (DEBUG)  {   Serial.println(F("AltSoftSerial started at 9600"));     }
    newData = false;
    recvWithStartEndMarkers();
    if (newData)  {   processCommand();  }
int getjarak1()
   //Sensor1
  int sen_val1 = analogRead(A0);
  x1 = sen_val1  * 5.0/1023.0;
  y1= a * x1 + (1 - a) * y1_1;
   delay(50);
  y1_1 = y1;
    //Sensor 1
if(y1>=1.6 && y1<2.84)  {
 jarak1 = 66.139-(y1/0.0603); //sensor3 20-40
 else if(y1>=1.27 && y1<1.6)  {
 jarak1 = 89.876-(y1/0.0322); //sensor3 40-50
 else if(y1>=0.9 && y1<1.27) {
 jarak1 = 118.925-(y1/0.0186); //sensor3 50-70
else if(y1>=0.76 && y1<0.9) {
jarak1 = 134.296-(y1/0.0142); //sensor3 70-80
else if(y1>=0.64&& y1<0.76) {
jarak1 = 142.683-(y1/0.0123); //sensor3 80-90
return jarak1;
void processCommand()
  if (DEBUG){
     Serial.println(receivedChars);
     if (strcmp ("kirimjarak",receivedChars) == 0)
         float jarak = getjarak1();
         BTSerial.print("<");
         BTSerial.print( jarak );
         BTSerial.print(">");
if (strcmp("Pinbutton", receivedChars) == 0 )
     char receivedChars[100]= "Pinbutton, buttonState1, buttonState2, buttonState3";
     char *token = strtok(receivedChars, ",");
 // DOWN
      token = strtok(NULL, ",");
      if(token[0] == 'a' ) {
        digitalWrite(ledPin1, HIGH);
      Serial.print(",");
      if (token[0] == 'b' ) {
 // UP
      if(token[0]== 'c') {
        digitalWrite(ledPin2, HIGH);
      Serial.println(",");
      if(token[0]== 'd') {
 // EMERGENCY
      if(token[0]== 'e')  {
        digitalWrite(ledPin3, HIGH);
      if(token[0]== 'f')  {
      if (DEBUG) {
      Serial.print("jarak : ");
      Serial.print(receivedChars);
      Serial.println("");
     newData = false;
     receivedChars[0]='\0';
void recvWithStartEndMarkers()
     static boolean recvInProgress = false;
     static byte ndx = 0;
     char startMarker = '<';
     char endMarker = '>';
     char rc;
     if (BTSerial.available() > 0)
          rc = BTSerial.read();
          if (recvInProgress == true)
               if (rc != endMarker)
                    receivedChars[ndx] = rc;
                    ndx++;
                    if (ndx > maxDataLength) { ndx = maxDataLength; }
                     receivedChars[ndx] = '\0'; // terminate the string
                     ndx = 0;
                     newData = true;
          else if (rc == startMarker) { recvInProgress = true; }
And this My Code For [MASTER]
#include <Wire.h>
#define button1 5
#define button2 6
#define button3 7
int buttonState1 = 0;
int buttonState2 = 0;
int buttonState3 = 0;
unsigned long startTime = 0;
unsigned long waitTime = 1000;
unsigned long startTime2 = 0;
unsigned long waitTime2 = 1000;
  pinMode(button1, INPUT_PULLUP);
  pinMode(button2, INPUT_PULLUP);
  pinMode(button3, INPUT_PULLUP);
  if (DEBUG)
    if (DEBUG)  {  Serial.println("AltSoftSerial started at 9600");     }
    newData = false;
    startTime = millis();
} // void setup()
    if (  millis()-startTime > waitTime )
       BTSerial.print("<kirimjarak>");
       if (DEBUG) {
       Serial.println("Request sent1"); }
    if ( millis() -startTime2 > waitTime2 )
      delay(100);
      BTSerial.print ("<Pinbutton,");
      buttonState1 = digitalRead(button1);
      buttonState2 = digitalRead(button2);
      buttonState3 = digitalRead(button3);
      if (buttonState1 == HIGH){
        BTSerial.print('a');
      else {
        BTSerial.print('b');
      BTSerial.print(",");
      if (buttonState2 == HIGH){
        BTSerial.print('c');
      else {
        BTSerial.print('d');
      if(buttonState3 == HIGH){
        BTSerial.print('e');
      else {
        BTSerial.print('f');
      if (DEBUG) { Serial.println("Request sent1"); }
      startTime2 = millis();
    if (newData)
         if (DEBUG) {
         Serial.print("Data received Distance :"); }
         Serial.println( receivedChars );
         newData = false;
     char rc;
                    ndx++;
                     ndx = 0;
                     newData = true;
