Controling LEDs
Can someone please advise me, I am building a model and want to control multiple LED diodes Chasing and various patterns. I need to know what board I need and if I require anything else.
Many thanks
How many is "multiple"?
Define "control".
Up to 1000 LEDs
All individually?
chrismunt2424:
Up to 1000 LEDs
You need a Mega because anything else will not have the memory. You also need to use an addressable LED strip like a WS2812b, sometimes called Neopixels.
Is it possible for me to use individual LED Diodes with 5 groups of 200
Yes but it will affect how you wire things up and make it more complex. You can achieve the same effect with an LED strip and software..
This is turning into an X-Y Problem
Please read this:-
How to use this forum because it will tell you how to ask a question correctly.
PieterP:
I really like the Teensy 3.2. It has a 32-bit ARM Cortex-M4 that runs up to 96MHz, 64KB of RAM and 256KB of flash. I/O is 5V tolerant.
With a PCB size of 36x18mm, it's even smaller than the Arduino Nano.
Arduino compatibility is excellent, never had any problems.
It supports up to 4,000 Neopixels and uses DMA to minimize CPU load when driving them.
OctoWS2811 LED Library, Driving Hundreds to Thousands of WS2811 LEDs with Teensy 3.0
The results are pretty impressive: OctoWS2811 LED Library - YouTube
Pieter
from PieterP on my thread
