Hi,i having problem with the code to control an ordinary dc motor by using Ethernet shield + Uno for opening and closing small window and lighting led on/off ,thanks!
If you don't post it, we can't help you.
It also helps tremendously if you say what the actual problem is.
My project is home automation, my problem is to control a dc motor to open and close a small window in details,i need a code to control this motor in both diction's,how i can do this?
DPDT relay or H-bridge.
Thank you, what about the code?
That's what you write when you've specified the hardware.
motor number (RF-300F-12350) and transistor 2N2222
I thought you wanted the motor to be able to reverse?
zorro2050:
You write the code yourself - or go to the Gigs and Collaborations section and ask somebody to write it for you (most people would expect to be paid for working for you).
If you can't make your code work and need help there are plenty of people here who will give advice and suggestions, but you should expect to do the bulk of the work yourself.
