Controling relay or valve pin with serial input
I have the following code that opens and closes a solenoid valve. However I would like to press O for Open Or C for Close on the keyboard and this should send digitalWrite(pin, LOW); / digitalWrite(pin, HIGH); to my arduino.
#define VALVE_PIN 2
class valveControl {
//defining attributes
private:
byte pin;
public:
valveControl(byte pin) {
// Use 'this->' to make the difference between the
// 'pin' attribute of the class and the
// local variable 'pin' created from the parameter.
this->pin = pin;
init();
void init() {
  pinMode(pin, OUTPUT);
  // Always try to avoid duplicate code.
  // Instead of writing digitalWrite(pin, LOW) here,
  // call the function off() which already does that
  off();
void on() {
void off() {
}; // don't forget the semicolon at the end of the class
class valveControler {
// class definition
valveControl valve(VALVE_PIN);
void setup() { }
valve.on();
delay(100000);
valve.off();
delay(100000);
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Do you know how to read a character from the keyboard and test its value ?
Welcome
Would you share code examples?
consider
#define VALVE_PIN 2
enum { Open = HIGH, Close = LOW };
void loop ()
    if (Serial.available ())  {
        char c = Serial.read ();
        if ('o' == c)
            digitalWrite (VALVE_PIN, Open);
        else if ('c' == c)
            digitalWrite (VALVE_PIN, Close);
void setup ()
    Serial.begin (9600);
    pinMode      (VALVE_PIN, OUTPUT);
Helped me a lot!
@19940224Alex, i'm curious, why did you start with a class?
I study Computer Science and we are thought to code in OOP rather than procedural programming. Also there are other components/ objects that I would like to add. Still a newbie.
