controling servos between 2 arduino's over serial
hi
I’m looking into building a serup where 1 arduino reads a couple of Pot meters and sends the data to an other arduino that controlls and equal amount of servos. (they communicate over xbees)
right now i’m trying with just one servo/pot setup and a serial line
i’ve set up an arduino with a pot meter and a servo and modified the servo-knob example to also output to serial
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott http://people.interaction-ivrea.it/m.rinott
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int potpin = 0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
myservo.attach(9); // attaches the servo on pin 9 to the servo object
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
Serial.print(val);
delay(15); // waits for the servo to get there
and wrote a skech to read the serial and write it to a servo
#include <Servo.h>
int incomingByte = 0; // for incoming serial data
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
// send data only when you receive data:
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
myservo.write(pos);
Serial.print(pos);
i suspect i am doing something wrong with how i send/recieve the serial data, but can’t for the life of me figure it out
anny ideas welkom
kind regards
corosus
On the sending end, you probably need to add a delimiter (kike the , below) to the val sent. On the receiving end you might use code like below.
//zoomkat 3-5-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
// CR/LF could also be a delimiter
String readString;
#include <Servo.h>
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-delomit-test-22-dual-input"); // so I can keep track of what is loaded
  //expect a string like 700, or 1500, or 2000,
  //or like 30, or 90, or 180,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          myservo.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          myservo.write(n);
        //do stuff with the captured readString
        readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
