Controling stepper motor speed
I have this code, and i'm trying to control the motor speed(0, back(- num), forward( num)), with putting numbers in the serial monitor but after the first number its not letting me enter new number:
int half_step[8] = {1, 3, 2, 6, 4, 12, 8, 9};
int idx = 0;
int motorSpeed = 5; // Default motor speed (in milliseconds)
int currentSpeed = 0; // Current speed setting
int newSpeed =0;
int newvalue = 0;
  Serial.setTimeout(2);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  digitalWrite(8, 0);
  digitalWrite(9, 0);
  digitalWrite(10, 0);
  digitalWrite(11, 0);
  while (Serial.available()&& newvalue == 0)
    newvalue = 1;
    newSpeed = Serial.parseInt();
    Serial.read();
    Serial.println(newSpeed);
    if (newSpeed == 0 && newvalue==1)
      Serial.println("if enter 0:");
      stopMotion();
      newvalue=0;
    else if(currentSpeed != newSpeed && newvalue ==1)
      Serial.println("if enter not the same:");
      currentSpeed = newSpeed;
      newvalue = 0;
      Serial.println(currentSpeed);
      setMotorSpeed(currentSpeed, newvalue);
void setMotorSpeed(int currentSpeed,int newvalue)
  motorSpeed = abs(currentSpeed); // Set the speed (positive value)
  int direction = (currentSpeed > 0) ? 1 : -1; // Determine the direction
  while (currentSpeed == newSpeed && newvalue == 0)
    Serial.println("while:");
    PORTB = half_step[idx];
    delay(motorSpeed);
    idx += direction;
    if (idx > 7) idx = 0;
    if (idx < 0) idx = 7;
    Serial.println(newvalue);
void stopMotion()
  currentSpeed = 0;
  motorSpeed = 0;
  PORTB = 0;
  Serial.println("Motion stopped");
  newvalue=0;
see Reading Integers from Serial Communication - #5 by gcjr
it is not safe to overwrite OSC pins
