controling two Arduino on the same LAN
hello every one ,
I already connect two Arduino at the same LAN and connect them to each other
but the problem now is how to make one of them send an message and make one of them receive it
i have
Arduino UNO with Ethernet shield (i connected by a wire)
Arduino YUN (i connected by wifi)
Why is that a problem? One acts a server. The other acts as a client. The clients sends a GET request. The server provides a response.
PaulS:
.... and you could probably base your solution on the WebServer and Webclient sketches in the IDE, with appropriate MACs and IPs, and the right GET and response.
that what i did
the UNO is the server
the YUN is the client
the YUN send GET request to UNO
the UNO send GET request to YUN
that how i connect them
i have 4 led
this 4 led attached to UNO
i want to control these LED from the YUN by 4 push buttons
Have the code at the client add a ?LEDxON or similar to the GET which you send to the server. Then the server checks for that text in the arriving GET and if it finds LED1ON or LED2ON or whatever, acts accordingly.
that what i did
Serving porridge? Where is your code?
Making what kind of request? Getting what kind of response? Where is your code?
This is NOT the "Do my homework for me hotline". You need to post your code.
this the code for UNO
// FILENAME = LED2.ino
// SOURCE= http://www.instructables.com/id/Control-an-LED-over-the-internet-using-the-Arduino/
// Control an LED over the internet using the Arduino Ethernet Shield and Transistor
// http://www.instructables.com/id/Control-an-LED-over-the-internet-using-the-Arduino/
// code SOURCE= http://pastebin.com/CZ6J62qJ
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
#include <HttpClient.h>
// initialize the library with the numbers of the interface pins
Servo myservo; // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 177 }; // fixed IP addr in LAN
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
void setup(){
pinMode(6, OUTPUT); //pin selected to control LED
pinMode(7, OUTPUT); //pin selected to control LED
pinMode(8, OUTPUT); //pin selected to control LED
pinMode(9, OUTPUT); //pin selected to control LED
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//the pin for the servo co
//enable serial data print
Serial.println("server LED test 1.0 ---- FILENAME = LED2.ino "); // so I can keep track
while (!Serial); // wait for a serial connection
void loop(){
    HttpClient client;
   client.get("http://192.168.1.4");
    if (client.available()){
  Serial.println("Avilable");
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Local network EX</TITLE>");
client.println("</HEAD>");
client.println("<BODY bgcolor='#FFFDD8'>");
client.println("<H1>Local network ex</H1>");
client.println("
client.println("TEST number 2");
client.println("
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
  else {
        Serial.println("connection failed");
///////////////////// control arduino pin
if(readString.indexOf("?lightR") >0)//checks for on
digitalWrite(7, LOW);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(6, HIGH);
Serial.println("LED RED");
if(readString.indexOf("?lightG") >0)//checks for off
digitalWrite(6, LOW);
digitalWrite(7, HIGH);
Serial.println("LED GREEN");
if(readString.indexOf("?lightY") >0)//checks for off
digitalWrite(8, HIGH);
Serial.println("LED YELLOW");
if(readString.indexOf("?lightO") >0)//checks for off
digitalWrite(9, HIGH);
Serial.println("LED ORANGE");
if(readString.indexOf("?A") >0)//checks for off
Serial.println("LED closed");
readString=""; //clearing string for next read
this the code for YUN
  Yun HTTP Client
 This example for the Arduino Yún shows how create a basic
 HTTP client that connects to the internet and downloads
 content. In this case, you'll connect to the Arduino
 website and download a version of the logo as ASCII text.
 created by Tom igoe
 May 2013
 This example code is in the public domain.
 http://arduino.cc/en/Tutorial/HttpClient
#include <Bridge.h>
  // Bridge takes about two seconds to start up
  // it can be helpful to use the on-board LED
  // as an indicator for when it has initialized
  pinMode(13, OUTPUT);
  digitalWrite(13, LOW);
  Bridge.begin();
  digitalWrite(13, HIGH);
  // Initialize the client library
  HttpClient client;
  // Make a HTTP request:
  client.get("http://192.168.1.177");
  else {
  // if there are incoming bytes available
  // from the server, read them and print them:
  delay(5000);
So what's the question? How to send the GET from the client?
Looks like you have the server side taken care of.
I've not used that http library but it looks as if the client.get sends a literal as part of a GET. So I'm surmising you could send a literal that contains the parts you're looking for in the server.
Along the lines of (and this is a wild guess)...
if (button1 == HIGH) {
client.get("lightG");
Disclaimer: wild guess
Why are you trying to use both an HttpClient and an EthernetClient on the same Arduino? Why is the HttpClient making a GET request?
Why is your code so poorly indented? Use the Tools + Auto Format function!
client.println("
client.println("
What is a client that connects to this server supposed to do with this? There is nothing here that tells a client what to do.
What is there that suggests that it is reasonable for the client to add this bit to the GET request?
Is the server supposed to be driving the client? Or is the client supposed to be driving the server?
What serial output are you seeing?
I think it would be more like:
                                    client.get("http://192.168.1.177?lightG");
to keep up the poor indenting, etc. And, of course, it looks like HttpClient::get() needs a complete URL.
sorry for that , thats because im still work on it
well i need it to controlling the LEDs from my computer (i will work on it later )
the client driving the server
I try it but i need to send this code to time to activate the LED why ?
Your computer is neither the server nor the client. So, what role is is supposed to play?
Because that's what the server expects.
Sorry I mean two times
I should send the code two time to activate the led
Also when I use if function to send the code to the server nothing are happened
Why? You should not need to, and you most certainly do not want to set up a situation where that is necessary.
So, you've made code changes (or should have), and you'd like us to guess what you changed, and what serial output you are seeing, having added Serial.print() statements to debug the code. You did add them, right?
No idea..... although maybe it's becasue I think this:
is missing a / before the ?
client.get("http://192.168.1.177/?lightG");
i attached the push button to pin 7 on the client
i attached 4 led to pin 6 , 7 , 8 and 9 on the server
the codes
the server
#include <SPI.h>
#include <Servo.h>
String readString;
void setup(){
//start Ethernet
server.begin();
void loop(){
if (client) {
readString += c;
//Serial.print(c);
if (c == '\n') {
client.println();
client.println("
client.println("
delay(1);
//stopping client
client.stop();
client
  Yun HTTP Client
 created by Tom igoe
 May 2013
#include <Bridge.h>
const int buttonPin = 7;     // the number of the pushbutton pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
   pinMode(buttonPin, INPUT);
  Bridge.begin();
    HttpClient client;
  if (buttonState == HIGH) {
      Serial.println("work");
  client.get("http://192.168.1.177?lightO");
  else {
But, you have no intention of telling us what you see. Well, good luck.
Why?
Code:
GET /?lightO HTTP/1.1
The LED activated only when i open serial monitor
