Controling Ultra Torque Hi-tec Servo motors using Arduino
These are the two functions in the library
void Servo::write(int value)
    if (value < MIN_PULSE_WIDTH)
    {  // treat values less than 544 as angles in degrees (valid values in microseconds are handled as microseconds)
        if (value < 0) value = 0;
        if (value > 180) value = 180;
        value = map(value, 0, 180, SERVO_MIN(), SERVO_MAX());
    this->writeMicroseconds(value);
void Servo::writeMicroseconds(int value)
    // calculate and store the values for the given channel
    byte channel = this->servoIndex;
    if ((channel < MAX_SERVOS))  // ensure channel is valid
        if (value < SERVO_MIN())  // ensure pulse width is valid
            value = SERVO_MIN();
        else if (value > SERVO_MAX())
            value = SERVO_MAX();
        value = value - TRIM_DURATION;
        value = usToTicks(value);  // convert to ticks after compensating for interrupt overhead - 12 Aug 2009
        uint8_t oldSREG = SREG;
        cli();
        servos[channel].ticks = value;
        SREG = oldSREG;
Note the comment in the write() function
