controll servos
Hello guys,
i'm a new one , and i have questions for controlling servos. i modified a code for controlling 5 servos,but just 2 servos can be moved in the process.
Could you please tell me the reason and how to modify, thank you so much.
int servopin=9;
int servopin1=10;
int servopin2=11;
int servopin3=6;
int servopin4=5;
int myangle;
int pulsewidth;
int val;
void servopulse(int servopin,int myangle)
pulsewidth=(myangle*11)+500;
digitalWrite(servopin,HIGH);
delayMicroseconds(pulsewidth);
digitalWrite(servopin,LOW);
delay(20-pulsewidth/1000);
pinMode(servopin,OUTPUT);
pinMode(servopin1,OUTPUT);
Serial.println("servo=o_seral_simple ready" ) ;
val=Serial.read();
if(val>'0'&&val<='9')
val=val-'0';
val=val*(180/9);
Serial.print("moving servo to ");
Serial.print(val,DEC);
for(int i=0;i<=50;i++)
servopulse(servopin,val);
servopulse(servopin1,val);
servopulse(servopin2,val);
servopulse(servopin3,val);
servopulse(servopin4,val);
How are you powering your servos? Powering servos from the arduino causes problems. Servos need an external power supply.
zoomkat:
Thank you for your answering, but i don't think this is the reason. Because I use external power for servos and use usb power for arduino.
If i upload code as follow, then my 5 servos can move and at same time.
// Multi Sweep, Duane B
// Using the servo library created by Michael Margolis
// to control 12 Servos with one Arduino Uno
#include <Servo.h>
// Sample sketch for driving 12 Servos from an Arduino UNO, servos are attached to digital pins 2,3,4,5,6,7,8,9,10,11,12,13
#define CONNECTED_SERVOS 12
// macro just adds two - the first servo is attached to digital pin 2, this gives us upto 12 servos - digital 2 to 13
#define SERVO_TO_PIN(x) (x+2)
int val;
Servo myServos[CONNECTED_SERVOS];
#define COUNT_DOWN -1
#define COUNT_UP +1
#define INCREMENT 10 // move in steps of 10 milliseconds
int nPulseWidth = DEFAULT_PULSE_WIDTH ; // 1500, defined in servo.h
int nDirection = COUNT_UP;
volatile unsigned long ulStart = 0;
volatile unsigned long ulStartToEnd = 0;
 // attach the servos
 for(int nServo = 0;nServo < CONNECTED_SERVOS;nServo++)
   myServos[nServo].attach(SERVO_TO_PIN(nServo));
 // the library sets all servos to 1500 ms pulse width by default, this is center for a steering servo
 Serial.println("Completed setup");
    if(ulStartToEnd)
     Serial.println(ulStartToEnd);
     ulStartToEnd = 0;
     nPulseWidth += nDirection * INCREMENT;
     if(nPulseWidth >= 2000)
       nPulseWidth = 2000;
       nDirection = COUNT_DOWN;
 if(nPulseWidth <= 1000)
   nPulseWidth = 1000;
   myServos[nServo].writeMicroseconds(nPulseWidth);
Do you Below is some servo test code you can try to see if you can the servos to move at the same time, Also read #7 below about how to post your code:
http://forum.arduino.cc/index.php/topic,148850.0.html
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or combined like 30c,180b,70a,120d,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
Hi zoomkat,
Thank you for your help about the code and how to post code.I use your code to test and 4 servos can work well, so I think it's my code problem.
 if(val='1') {
    delay(10);  // give the servos time to move after each update
  1. Assigning val the value of '1', in an if statement, seems pointless. == is used to compare values
  2. That comment is flat ass wrong. One delays AFTER telling a servo to move, to give it time to get there. Delaying BEFORE moving a servo just wastes time.
PaulS:
 if(val='1') {
1) Assigning val the value of '1', in an if statement, seems pointless. == is used to compare values
2) That comment is flat ass wrong. One delays AFTER telling a servo to move, to give it time to get there. Delaying BEFORE moving a servo just wastes time.
You are right, the commands that you point is added by me and i forgot to delete.
I am learning programming for controlling 5 servos and use serial monitor to give a signal. The first code i posted that just can control 2 servos (pin9,10) and i don't know what is the problem. For second code , the original code can control 5 servos and i want to modify code to use serial monitor to give a signal.
Could you please give me some advice about the first code? I'll appreciate.
The first code does not use the Servo class.
The second code does.
Certainly. Delete it. Make the second code do what you want.
