hi,
i've a nema 23 stepper motor, 3A - 0.95 ohm, for this project i need to controll the torque of the motor:
from my code i recive a pwm signal (0-255) that rappresent the % of torque i need to generate from the motor.
i've searched for a driver with dynamical adjust of current but i haven't found anything.
can someone give me some tips or reference to documentation?
IF that is the real requirement, then a stepper motor is the wrong choice. A stepper has turning torque when it takes a step. It also has holding torque when stationary, between steps. They are very similar values. There is no easy way to adjust the current being produced by a stepper motor controller board.
Perhaps the use of a regular DC motor will work for your project.
i've thinked to use DC motor, but they have too small quantity of torque.
also i need a "Brake" usage of the motor.
i need my motor torque to be adjustable so you can rather win the forces applied or slips steps when it's to low.
Some drivers allow to adjust the maximum current and control that current by self-generated PWM. Typically the current is set by a pot, while you need a different adjustment method. If you cannot find a controllable current limit driver then I only can imagine an additional circuit that affects the PWM generation.
i currently have a TB6600, wich allows me to adjust current to 3.5 Amps or low with a pot, i was thinking of getting a PWM mofset to use on DC input of the driver.
could this work as intend ?
i've made some experiment, and sadly it doesn't work...
i've succeced to reduce torque, and increase it manually turning on and off the switches and i've searched for a new stepper controller with adjustable curret limit signal (current one "TB6600" has switch pot ) and i've found the DRV8825, too bad it's only 2.5 amps.
if someone can advise me with a more suitable driver would be very lovely.
