Hi everyone ![]()
I'm working on a project which involves controlling the lowering of a loaded platform. My current plan involves a motor turning a threaded rod passing through the platform, similar to a 3D printer.
A load on the platform is only applied when it is being lowered or held stationary. When the platform reaches the bottom of the rod, its load can be removed and I plan for the motor to be reversed to send the much lighter unloaded platform back to the top of the rod.
I'm hoping that using this configuration will limit the load on the motor to just friction between the rod and the platform, (other than the reset), as I am trying to deal with reasonably large masses on the platform, ~3-5kg.
Does anyone have any recommendations on which kind of motor could be most appropriate to this application, considering it may need to resist some torque to stop the platform dropping too quickly / stop it moving all together? If its at all possible, ideally it should be extremely quiet as well.
Thank you so much for any help whatsoever! Please let me know if I can explain anything better.
