Controllig a brushed DC motor with a 50a pwm speed control using arduino
I am upgrading the control system for a dc motor which drives a seeder.
The old system was simply a speed controller,
and a hall effect sensor displaying rpm to the operator. It was up to the operator to continually make adjustments to the speed controller pot to maintain rpm under varying conditions.
What I would like to do is control the same speed controller with an arduino which varies the output to maintain a preselected rpm. Set and forget. I hope.
Being a simple minded person, I assumed that if I measure the voltage range on the centre pin of the adjustment pot of the speed controller, and then reproduced that voltage range on an output pin of the arduino uno, I could simply remove the pot and connect arduino out and gnd to the speed controller.
This does not seem to be the case. >:(
Can anybody suggest how I can take control of this speed control with an arduino?
sketch attached for reference.
This is still a work in progress.
 * This controller is to replace the standard controller found on "Seabrook Seeders".
 * The standard controllers do not have motor feedback to the speed controller
 * despite having a hall effect sensor fitted to the output shaft. Therefore, any
 * variation in voltage or load would destroy any hope of maintaining consistant RPM
 * thus making calibration impossible.
 * This controller allows the user to set the required rpm via up/down buttons and
 * the controller then adjusts the esc to maintain the selected rpm. If the selected
 * rpms are unable to be maintained due to motor overload, a warning buzzer will sound and a message will
 * appear on the screen.
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins.
//Non standard pins are used. Need to be changed for DFRobot lcd.
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
int read_LCD_buttons() {              // read the buttons
  adc_key_in = analogRead(0);       // read the value from the sensor
  if (adc_key_in>1000) return btnNONE;
  if (adc_key_in < 50)   return btnRIGHT;
  if (adc_key_in < 195)  return btnUP;
  if (adc_key_in < 380)  return btnDOWN;
  if (adc_key_in < 555)  return btnLEFT;
  if (adc_key_in < 790)  return btnSELECT;
  return btnNONE;                // when all others fail, return this.
//Define integers
// digital pin 13 has a hall effect sensor attached to it.
  int sensor = 13;
// Analog (pwm) output pin 11 that the ESC is attached to
  int escOut = 11;
  int escSet;
//Define RPM variables.
volatile byte rpmcount;
unsigned int rpm;
unsigned long timeold;
  //Define strings
  String st1="Req'd RPM ";
  String st2="Actual RPM ";
void rpm_fun(){
rpmcount++;
  // set up the LCD.
    lcd.begin(16, 2);
    lcd.setCursor(0, 0);
    lcd.print("Seedr Controller");
    lcd.setCursor(1, 1);
    lcd.print("by Chris Dalby");
    delay(5000);
    lcd.clear();
    lcd.print("Set RPM");
    // initialize the serial communications:
    pinMode(sensor, INPUT);
    pinMode(escOut, OUTPUT);
   //Interrupt 0 is digital pin 2, so that is where the IR detector is connected
   //Triggers on FALLING (change from HIGH to LOW)
   attachInterrupt(0, rpm_fun, FALLING);
   //Turn on IR LED
   pinMode(ledPin, OUTPUT);
   digitalWrite(ledPin, HIGH);
    escSet=25;
    rpmcount = 0;
    rpm = 0;
    timeold = 0;
  delay(200);
  lcd.setCursor(0,0);
  //Read keypad and adjust escSet.
  lcd_key = read_LCD_buttons();   // read the buttons
   switch (lcd_key){               // depending on which button was pushed, adjust escSet up or down.
       case btnRIGHT:{
       case btnLEFT:{
       case btnUP:{
            int (escSet=escSet+1);
            //Trying to set upper limit of RPM to 60.
           /* if (escSet >=60);{
              int (escSet=60);
            lcd.clear();
            lcd.print(st1);
            lcd.print(escSet);
       case btnDOWN:{
            int (escSet=escSet-1);
            //Trying to set lower limit of 5.
          /*  if (escSet <=5);{
              int (escSet=5);
            lcd.clear();
            lcd.print(st1);
            lcd.print(escSet);
       case btnSELECT:{
    //Don't process interrupts during calculations.
   detachInterrupt(0);
    //Note that this needs to be adjusted to suit number of slots in disc and 200ms time window.
   rpm = 30*1000/(millis() - timeold)*rpmcount;
   timeold = millis();
   rpmcount = 0;
   lcd.setCursor(0,1);
   lcd.print(st2);
   lcd.print(rpm);
  //Need to develope code for setting escOut according to rpm:escSet.
   if (rpm>escSet){
      escOut=escOut-1;
   else if (rpm<escOut){
      escOut=escOut+1;
   escOut=escOut;
   //escOut limited to 100/255 to deliver max Vout of 1.95v for esc.
   if (escOut>100){
    escOut=100;
  //Code to send escOut to pin 11
  Serial.println(escOut);
  analogWrite(11,escOut);
Maybe a digital potentiometer might be what you need?
example. https://www.sparkfun.com/products/10613
Definitely an option thanks alka. Great!
I just discovered this esc has a “hall effect” input for control. Problem solved.
