controllin dc motor with lm35 using arduino.
hello, i want to write a program to control dc motor using lm 35. for first time, if temp reaches 75 the motor should be stopped..then from next loop if temp is less than 55 , motor should be on..pls help me out..i dont know programming in arduino.. :relaxed:
Split the problem into it's two parts....
Write a program to turn the motor on and off as you press a button.
Write a program to turn an LED on and off, depending on the temperature seen.
Once those are working, blending them into a single program is relatively easy.
For a course on Arduino programming...
http://sheepdogguides.com/arduino/FA1main.htm
For motors you will need some hardware to drive them. See:- http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
