I'm just starting with LEDs. First I thought I use a SN74HC595N shift register, but then I found the TLC5940 (16-Channel LED Driver w/EEprom DOT Correction & Grayscale PWM Control)
What I want to achieve: Control 12 (maybe later 24) LEDs, (turn on/off and dim them).
TLC5947 (has 24 channels) would be perfect imho. But there is no DIP package - and the only breakout board I found is from Adafruit - and pretty expensive.
Are there alternatives?
Well if $15 is considered expensive what budget are you on?
The alternative is to buy an undedicated breakout PCB from eBay and solder it on yourself, it is not hard.
Grumpy_Mike:
Compared to the 5$ of the chip $15 is quite a lot. And the Adafruit breakout board has stuff that I don't need (e.g. the voltage regulator).
If you can't solder a surface mount chip then the $10 is for some on to do it for you.
An other alternitave is to use the 5mm neopixels.
vile
May 13, 2015, 5:09am
5
In my project, I first used the TLC5940, but then I found the PCA9685 which I think is much easier to use, since it communicates via I2C and adafruits library works great.
I bought some PCA9685 in TSSOP28 package from ebay (Link ), adapters (Link ) and soldered the chips as shown in this video: Drag soldering SMD parts with a flux pen .
For my project, this is the best solution.
vile:
Thanks a lot for your post! The PCA9685 indeed seems to be a very good choice:
2.3 V to 5.5 V
inexpensive (under 2$ from Farnell)
TSSOP28 (TLC5947 has TSSOP32 and the adapters are way more expensive than TSSOP28 ones)
I2C
It's just: I've never hand soldered SMD before. Dave Jones has a very nice video covering different techniques: EEVblog #186 - Soldering Tutorial Part 3 - Surface Mount - YouTube . So I might just give it a go.
