What I want to know is it possible to setup the wire connection with 1 external power source hooked up to the relay and another 1 (12V) to the relay connecting the pump? Do I need any of the flyback diode or anything extra to control it?
Sorry I am a newbie to all of this,plus I read around the forum but can’t get any direct answers since some thread says yes some say no.I want it to be on the safe side.
Koepel:
You can use a single 12V power supply. There is no need to add extra things to it.
Is it a small peristaltic pump ? Those require 0.5 A maximum. You can also use transistors or mosfet for those.
So I wont need to worry about the back emf or whatsoever?Well im planning to up the project to use multiple pump.But testing with one and messing around the config first.
No, the relais contacts should be good enough to switch the motor on and off.
It doesn't hurt to add a snubber circuit, but that is probably not needed.
Sometimes there are small capacitors on the motor itself, to reduce sparks.
The relais board is so big. A few mosfets, resistors, and flyback diodes is more fun.
Koepel:
