Ok so Im working on an Etch a sketch type project working from a printer with two DC motors. Im having a little trouble with the code. I cant seem to get the potpin2 to work with its motor. Can anybody helps? Sorry Im brand new, and this is one of my first arduino attempts.
thanks
* Arduino code for SN754410 H-bridge
* motor driver control. A potentiometer's
* 270 degree rotational angle is used to
* control a DC motor in the following way:
* 0-135 degrees - motor runs forward, speed
* getting slower the higher the angle, motor
* stops at 135 degrees.
* 135-270 degrees: motor runs backward,
* speed is getting faster the higher the
* angle, motor speed is 0 at 135 degrees.
* copyleft Feb. 2008, Fabian Winkler
int potPin1 = 0; // analog input pin 0 for the potentiometer
int potPin2= 1; // analog input pin 2 for the potentiometer
int speedPin1 = 9;// H-bridge enable pin for speed control
int speedPin2 = 10; // H-bridge enable pin for speed control
int motor1Pin = 1; // H-bridge leg 1
int motor2Pin = 2; // H-bridge leg 2
int motor3Pin = 11; // #2 H-bridge leg 1
int motor4Pin = 12; // #2 H-bridge leg 2
int ledPin = 13; // status LED
int val1 = 0; // variable to store the value coming from the #1 potentiometer
int val2 = 0; // variable to store the value coming from the #2 potentiometer
// set digital i/o pins as outputs:
pinMode(speedPin1, OUTPUT);
pinMode(speedPin2, OUTPUT);
pinMode(motor3Pin, OUTPUT);
pinMode(motor4Pin, OUTPUT);
pinMode(motor1Pin, OUTPUT);
pinMode(motor2Pin, OUTPUT);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH); // status LED is always on
val1 = analogRead(potPin1); // read the value from the potentiometer
val1 = val1 /4; // convert 0-1023 range to 0-255 range
if (val1 <= 127) {
// put motor in forward motion
digitalWrite(motor1Pin, LOW); // set leg 1 of the H-bridge low
digitalWrite(motor2Pin, HIGH); // set leg 2 of the H-bridge high
// control speed based on angle of potentiometer
analogWrite(speedPin1, 254-(val1*2)); // output speed as PWM value
// this value needs to go from 254 to 0 for input values
//from 0 to 127
// put motor in backward motion
else {
digitalWrite(motor1Pin, HIGH); // set leg 1 of the H-bridge high
digitalWrite(motor2Pin, LOW); // set leg 2 of the H-bridge low
analogWrite(speedPin1, (val1*2)-256); // output speed as PWM value
// this value needs to go from 0 to 254 for input values
// from 128 to 255
val2 = analogRead(potPin2); // read the value from the potentiometer
val2 = val2/4; // convert 0-1023 range to 0-255 range
if (val2 <= 127) {
digitalWrite(motor3Pin, LOW); // set leg 1 of the H-bridge low
digitalWrite(motor4Pin, HIGH); // set leg 2 of the H-bridge high
analogWrite(speedPin2, 254-(val2*2)); // output speed as PWM value
//from 0 to 127
else {
digitalWrite(motor3Pin, HIGH); // set leg 1 of the H-bridge high
digitalWrite(motor4Pin, LOW); // set leg 2 of the H-bridge low
analogWrite(speedPin2, (val2*2)-256); // output speed as PWM value
// from 128 to 255
