controlling 2 leds with 2 push buttons
I am using 2 push buttons to control 2 leds, one button specific to each.
when i change the state of one push button, corresponding LED lights up, but when i change the state of the other button, the other led should light up and first led should be written low.
I tried loops, but since the push button status is momentary, i have trouble keeping led in the HIGH state.
Have attached the code,
it is
const int VRAB = 7; //button 1
const int VRAL = 12; // led1
const int VRCB = 6; // button 2
const int VRCL = 11; // led 2
int val = 0;
int val1 = 0;
int state = 0;
int state1 = 0;
int jump=0;
pinMode(VRAB,INPUT);
pinMode(VRAL,OUTPUT);
pinMode(VRCB,INPUT);
pinMode(VRCL,OUTPUT);
val=digitalRead(VRAB);
val1=digitalRead(VRCB);
if(val==HIGH && val1==LOW)
{jump = 1; state=1; state1=0;}
else if(val==LOW && val1==HIGH)
{jump = 2; state=0; state1=1;}
switch (jump) {
 case 1:
 digitalWrite(VRAB,HIGH);
 digitalWrite(VRCB,LOW);
 case 2:
 digitalWrite(VRAB,LOW);
 digitalWrite(VRCB,HIGH);
Please help.
VR_case.ino (740 Bytes)
You should look at the StateChangeDetection example
edit... I had the wrong url in the link, sorry.... it's fixed now
Hi, please edit your post and use the </> icon to put your code inside code tags.
Paul
done
have used variables to detect state change.. doesn't seem to be working
Muhammad_Ubaid:
No, it seems to me you are looking for the current state, not the fact that it changed from last time through loop().
In these applications it's important to see that a pin has become high (or low), not that it is high (or low).
Muhammad_Ubaid:
done
Thankyou!
Your state variables seem to be tracking the state of the leds, not the state of the buttons. Like Jimbo says, right now, your code cannot tell if a button has changed state since it was last checked.
PaulRB:
Like Jombo says
That's new.... I get Jumbo instead of Jimbo, but never Jombo before :slight_smile:
yes, please tell me how do i check if my button state has changed from last time, that is my requirement
Muhammad_Ubaid:
That's EXACTLY what the state change detection example does. But I just noticed I pasted the wrong url into the link earlier, sorry about that... here's the correct link.
Thank you, will try out
