I'm starting out with an Arduino Nano and I would like to build a robot with the following components:
2 DC motors for movement
2 Stepper motors to rotate head and body
2 Servo motors to lift arms up and down
additional LEDs
My understanding (and I'd be more than happy to redirected and corrected), is that I would need either quite a few bridges or a shield in order to be able to connect all of these motors to the Nano.
Which sounds to be perfect, although it looks like I would need 2 in order to do the trick.
Is this a correct assumption or would I be able to control all of the above motors with just one shield?
I'm happy to take any further suggestion if this approach is not ideal or if I should be looking at this project from another angle.
You must estimate what performance the motors and servos need to have.
Then find those motors, read their needs like voltage and current. After that You can look for stepper and motor drivers, and power supplies.
The typical "small 5V stepper" uses four pins. The DC motors will use at least 2 each (3 if you need to be able to disable the drivers). The servos use one each.
That's 14 pins minimum out of your 20 pins. Are 6 pins enough for your 'additional LEDs'? Will there be no inputs?
As per controlling the motors, considering what you mentioned about using the Arduino pins directly, should I 'just' connect the motors to their related drivers and then reference the related pins in the code instead of going for a shield?
Sorry if this may sound as a stupid question, but I'm trying to wrap my head around the need for additional components Vs what's already available on the board.
If referring to a 28BYJ-48, best driven by a TPIC6B595 - which can control two per chip using only three pins for any reasonable number - and not a ULN2003. Since you need a driver anyway.
And if using my MobaTools lib to drive the steppers, you even don't bother with the serial shifting. The lib can control up to 4 of this steppers with shift registers connected to the SPI pins.
At the end of the dokumentation file there is a schematic for the HC4094. That doesn't differ much from the TPIC6B595. For the TPIC it should look like this ( cannot test it, because I dont' have one, with a HC595 and its pinning it works that way) .
Of course you don't need the lower one if you only have 2 steppers.
