Controlling 2 servos at the same time
Hi there,
I am making an animatronic Wheatley from portal 2 and I am working on the eye lid movement at the moment. I have to eye lids which are about 8 cm across and are made out of foam. I am going to use two servos to move the eyelids.
I want to be able to control the servos at the same time, I will be using a 2 axis joystick to control the servos, but I will only use the up down motion to control the servos. I am very ignorant when it comes to this sort of thing. I am not sure what code I would need to write to control the servos using the joystick, could anyone help me with this? Any advice would be greatly appreciated :)
Many thanks
Rushmoore
The joystick produces a variable voltage which can be detected using analogRead()
You can use the value to cause a servo to move to a position determined by the voltage. Something like this crude example
   xaxisVal = analogRead(A0);
   servoPos = xaxisVal / 4; // to convert 0 to 1023 to 0 to 255 approximately
   myServo.write(servoPos);
   delay(100); // to allow time for servo to move - 50 might be enough
I don’t know how you want to control the second servo - should it be controlled separately ?
…R
look at the servo "knob" example in the arduino IDE examples. You can connect both servo signal wires to the single arduino pin.
