Controlling 240V with arduino
Hi Everyone, I want to write a circuit up so that a device that runs on a 240V mains power can be controlled via arduino. Reading forum posts before me it seems I need a relay that can be controlled via 5V and can hold 240V?
Can anyone recommend a part that I can buy to solve this issue? Thanks Mathew
Hello,
The best way is to use optocoupler and triac, more secure and quiet (no contact, no noise, no spark?)
I use the tuto gived in the wiring web site (excellent tutos)
http://www.wiring.org.co/learning/examples/Optocoupler_triac.html
Hope that helps
jhoepffner
Fatastic, Tho I was looking forward to the 'Click' sound but nevermind . lol
Thanks for your help. Mathew
for the click, you can replace the optocoupler by a relay, but the triac is definetly more secure than a little relay?
Not so sure !
A relay does not have any exposed parts connected to 220V lines, or get an SSR 'Sharp has goos ones) the optocoupler is already in !
If you want an authoritative click you'll need a contactor
http://en.wikipedia.org/wiki/Contactor
If you get one surplus they are pretty cheap. It's just a relay writ large.
You may have to get a much heftier transistor to activate one. If you choose one of these you will need a 24 or 28VDC power supply. If you look around you might find one that runs on a lower voltage but I've not seen one that runs on 5v.
http://www.surplussales.com/Relays/REcontacts.html
Be sure it's a DC coil one, there are ones that have a coil that needs AC.
Your next project could be a motorized switch, they look so rube goldberg!
