Controlling 24v 73a motor
Hello,
I am upgrading a motor from 12v to 24v that I am currently controlling with an Arduino. I am currently controlling it with a PWM motor controller and would like to stay there. I am not able to find a system for controlling a larger amperage motor with more voltage. The upgrade is because the gearbox upgrade I did isn't working successfully.
Thank you in advance.
Items read:
24V at 73A is 1.7 kW, so look for a motor controller than can handle at least 2 kW (better, 3 kW).
My Google-foo is failing me. I have tried searching for a couple of hours now. I came across flipsky controls and 3kw brushless dc bldc motor speed controller.
None of them look like they can support the voltage or the amps. I am finding either high 70v or 24v low amps.
I am not sure the keywords I should be after.
Maybe you should solve that problem, rather than buy a much higher power motor than required.
Something like this?
https://electromen.com/en/products/item/motor-controllers/dc-motor/EM-362/
