You need to look into using millis() for timing as in the BlinkWithoutDelay example and Several things at the same time
Save the time a servo move happens then each time through loop() check whether the required period has elapsed since the movement. If not then go round loop() again reading inputs etc. If the period has elapsed then take the required action. You can do this independently for 3 servos with the amount of sweep for each servo being random and different from the other two.
Robin2:
Try extending that code to use a second servo. If it does not work then post your code and tell us how it behaves.
And please use the code button </>
so your code looks like this
and is easy to copy to a text editor
...R
#include <Servo.h>
Servo myservo1; // create servo object to control a servo
// twelve servo objects can be created on most boards
Servo myservo2; // create servo object to control a servo
Servo myservo3; // create servo object to control a servo
int pos = 0; // variable to store the servo position
Can you guys help me improve this
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo.attach(8); // attaches the servo on pin 8 to the servo object
myservo.attach(7); // attaches the servo on pin 7 to the servo object
int randNumber = random(1, 3);
Serial.println(randNumber);
int del = random(1000, 16,000);
delay (del);
if randNumber = myservo1
// in steps of 1 degree
myservo1.write(90);
myservo2.write(90);
myservo3.write(90);
delay(2000);
myservo.write(0); // tell servo to go to position in variable 'pos'
// waits 15ms for the servo to reach the position
THIS IS WHAT I HAVE WRITTEN SO FAR.. please help..
UKHeliBob:
#include <Servo.h>
delay (del);
myservo1.write(90);
myservo2.write(90);
myservo3.write(90);
delay(2000);
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod; // create servo object to control a servo
//myservoa.writeMicroseconds(1500); //set initial servo position if desired
myservoa.attach(6); //the pin for the servoa control
myservob.attach(7); //the pin for the servob control
myservoc.attach(8); //the pin for the servoc control
myservod.attach(9); //the pin for the servod control
Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
//expect single strings like 700a, or 1500c, or 2000d,
//or like 30c, or 90a, or 180d,
//or combined like 30c,180b,70a,120d,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
if (readString.length() >1) {
Serial.println(readString); //prints string to serial port out
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.write(n);
if(readString.indexOf('b') >0) myservob.write(n);
if(readString.indexOf('c') >0) myservoc.write(n);
if(readString.indexOf('d') >0) myservod.write(n);
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
