Hello, i need to control 5 tilt and pan cameras, each tilt and pan camera is made from 2 servos, so there are 10 servos i need to control in realtime from one computer for my project. Is it possible to do this with one arduino? which hardware do i need for this task?
The Arduino only has enough hardware to run two servos directly, but there are software libraries that can drive more. If the Arduino has a lot of other things to do, I'd look into using one of these to offload most of the PWM work:
It's a Cypress chip that has gobs of hardware timers, so it should be more accurate and stable than juggling lots of software timers in the Arduino.
If the pan/tilts aren't very close together, it might be better to dedicate a low-cost Arduino (like the RBBB) to each to save cabling costs and hassles.
I sure would like to know how to use 2 serrvo's with the arduino 2009. I have seen al lot of links showing examples with only one and a few with more than one. One works ok. But the examples of using more than one servo tell me to use an other servo-lib. Then I get errors.
Ran, You seem to be saying that Arduino can only run two servos efficiently. That is not correct, the library linked above uses less than 1% of the available processing power to run 12 servos.
