Hey !
So I want to both have :
- the NFR24L01 wired to the arduino Nano (pins D7,D8,D11,D12,D13).
- and controlling 2 RGB 9W LED via 6 transistors via the same Nano.
The only way to make the LED light intensity to vary via the transistor is with a PWM pins right (and analogWrite) ? I have D3, D5, D6, D9 and D10 available, so only 5 transistors can be wired this way.
BUT the last PWM pin D11 is used by the MOSI pin of the NRF24, and apparently there's no way to change that. Too bad there's only 6 PWM pins on the Nano...
Am I stuck ? Is there another way to resolve that wiring limitation issue ?
Thanks for your help !
