Controlling 6 Stepper motors
I need help in selecting a shield for Arduino UNO that controls 6 stepper motors in the most space efficient way; I need to put that setup on a person's wrist.
Each of the stepper motor has to work with complete autonomy.
Opinions?
You may get some useful information in stepper motor basics.
Without knowing what motors you plan to use (post a link to their datasheet) it is impossible to know what motor drivers are needed.
I think the RAMPS boards (which use A4988 drivers) can have 4 drivers. I am not aware of a board with 6 of those drivers.
...R
the a498x are available on small prints, it makes it more flexible.
The RAMPS boards are designed for the Arduino MEGA 2560.
For 6 steppers you need 12 pins plus 6 Step & Direction drivers or 24 pins (4 per stepper) with enough current drive for your steppers. Perhaps three 8-bit shift registers. You can write shift registers at about 8 Megabits per second using SPI so that would allow about 300,000 steps per second, probably more than the steppers can stand.
