Controlling 8 led strips
I'm trying to scale up this project (https://www.youtube.com/watch?v=Hn9KfJQWqgI) to instead control 8 5m led strips. Using a 24 channel PWM signal breakout board. These are the strips (https://www.aliexpress.com/item/SMD-5050-RGB-LED-Strip-5M-10M-15M-12V-30-leds-m-Waterproof-Flexible-LED-Tape/32918119847.html?spm=a2g0s.9042311.0.0.143c4c4dX2jbb3) which will use 1.2A per 5m roll. I plan on having 8 5m rolls in parallel, so what is the best option for powering these strips? Is this schematic attached the right way to wire this circuit? The battery is meant to represent a 12v source, the resistors are meant to be 1k Ohm.
Fritzing file (https://drive.google.com/open?id=1HyCqHtTivdWp0o7mlh8eiHG16k7tgpun)
What makes you say that? They will consume more than that. They supply a 6A power supply which is more like it.
Please read the how to use this forum sticky post to find out how to post pictures and links. Your Fritzing link does not work, please post the picture as an attachment.
