controlling a buzzer and keypad using arduino
Hello everyone,
I'm trying to control a buzzer and a keypad using an Arduino Nano. The idea of this project is that a buzzer will turn on after 3 seconds when a button is pressed. The buzzer should turn off after the correct code is entered. The problems that I face are: When I used a delay(3000), during those 3 seconds none of the buttons on the keypad will be read. And I don't know how to program that the first button that is pressed (to activate the buzzer) won't count for the password.
#include <Key.h>
#include <Keypad.h>
#define buzzpin 2
#define DEBUG
const byte ROWS =1;
const byte COLS = 4;
char keys[ROWS][COLS] = {
  {'1','2','3','4'}
byte rowPins[ROWS] = {5};
byte colPins[COLS] = {8,9,6,7};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
char data[] = "    ";
int sequenceNum = 0;
  #ifdef DEBUG
  #endif
  pinMode(buzzpin, OUTPUT);
void loop(){
     char key = keypad.getKey();
     if (key != NO_KEY){ // if a key is pressed the buzzer should turn on after 3 seconds.
           Serial.println(key);
           delay (3000);
           digitalWrite(buzzpin, HIGH);
           Serial.print("buzzer activated");
     if (key){
    data[sequenceNum] = key;
    sequenceNum++;
    if (sequenceNum == 4){
      #ifdef DEBUG
      Serial.print(F("Code entered: "));
      Serial.println(data);
      #endif
      if(strcmp(data, "2341") == 0){ //if the correct code is entered the buzzer turns off.
        Serial.print("Correct   ");
        Serial.print("Buzzer disabled");
        digitalWrite(buzzpin, LOW);
        delay(100000000);
        Serial.print("Wrong");
      memset(data, 0, sizeof(data));
      sequenceNum = 0;
You can't control an input device. It will do what it wants.
Of course not. That's why there are something like 14 bazillion examples around of how not to use delay(). The blink without delay example, provided with the IDE, is the most basic.
Why not? Surely you can count the times that a button is pressed, and can distinguish between 0, 1, and more than one.
