Hi all,
I am trying to control a DC motor with Arduino via a L298N bridge. The idea is to run the motor in one direction for 3 times, with pauses in between. The duration of each run is the same and is specified as "forward", while the duration of the pause being "pause". Afterwards, the motor would be driven in the reverse direction, with the duration of the run given by "backward". This whole process is started by a push button and should keep repeating itself once it has started.
Here is the code that I have written. It ran fine for one time (i.e., 3 forward runs + 1 backward run) and then stopped and failed to repeat the steps. I am hoping to get your advice on how to modify the code such that:
Aim 1) the steps can keep looping
Aim 2) the steps can keep looping until a second push of the button, at which point everything should be reset. The program can then be reinitiated.
Thank you so much!
WY
#define enA 9
#define in1 6
#define in2 7
#define buttonPin 2
int forPwmOutput;
int backPwmOutput;
int pause;
int forward;
int backward;
bool buttonState;
unsigned long StartMillis;
pinMode(enA, OUTPUT); // To L298N Enable Pin
pinMode(in1, OUTPUT); // To L298N IN1
pinMode(in2, OUTPUT); // To L298N IN2
pinMode(buttonPin, INPUT); // From Button
void initialize() {
// Set initial rotation direction
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
// Set rotation speed
forPwmOutput = 255;
backPwmOutput = 255;
// Set amount of time for each action
pause = 2000;
forward = 2000;
backward = 4000;
// Set initial state of the button
buttonState = false;
StartMillis = 0;
while(buttonState == false) {
if (digitalRead(buttonPin) == HIGH) {
buttonState = true;
if ((buttonState == true) && (StartMillis = 0)) {
StartMillis = millis();
if (buttonState == true) {
// Moving to position 2
if (((millis() - StartMillis) >= pause) && ((millis() - StartMillis) < (pause + forward))) {
analogWrite(enA, forPwmOutput);
// Videotaping at position 2
if (((millis() - StartMillis) >= (pause + forward)) && ((millis() - StartMillis) < (2*pause + forward))) {
analogWrite(enA, 0);
// Moving to position 3
if (((millis() - StartMillis) >= (2*pause + forward)) && ((millis() - StartMillis) < (2*pause + 2*forward))) {
// Videotaping at position 3
if (((millis() - StartMillis) >= (2*pause + 2*forward)) && ((millis() - StartMillis) < (3*pause + 2*forward))) {
// Moving to position 4
if (((millis() - StartMillis) >= (3*pause + 2*forward)) && ((millis() - StartMillis) < (3*pause + 3*forward))) {
// Videotaping at position 4
if (((millis() - StartMillis) >= (3*pause + 3*forward)) && ((millis() - StartMillis) < (4*pause + 3*forward))) {
// Returning to position 1
if (((millis() - StartMillis) >= (4*pause + 3*forward)) && ((millis() - StartMillis) < (4*pause + 3*forward + backward))) {
digitalWrite(in1, HIGH); // Reverse rotation direction
digitalWrite(in2, LOW);
analogWrite(enA,backPwmOutput);
// At position 1
if ((millis() - StartMillis) >= (4*pause + 3*forward + backward)) {
initialize();
buttonState = true;
