I'm in the process of adding backlight for the LCD on my RC-transmitter and had a spare Nano, so I decided to go overkill on the control of it.
I have a input from the buzzer on the transmitter, (via a optocoupler)
and the plan was to light the backlight everytime it sounded, and after a couple of seconds it would fade to a lower light then turn completely off after a few more seconds.
after some tweeking of my second attempt, I got it to actually turn off, but the problem I have is that I want the light to stay on for 4 seconds after the LAST beep, now it is on for 4 (+8 at dim) seconds after the FIRST beep.
Can someone please help me?
Here is the code:
const int buzzerPin = 2; // Signal from buzzer
const int ledPin = 11; // Backlight
int buzzerState = 0;
void light(int state){
switch (state){
case 1: // full / half brightness
analogWrite(ledPin, 255); // full brightness on backlight
delay(4000);
analogWrite(ledPin, 200); // reduced brightness on backlight
delay(8000);
case 2: // turn off light
digitalWrite(ledPin, 0); // turn backlight off:
pinMode(ledPin, OUTPUT);
pinMode(buzzerPin, INPUT);
void loop(){
// read the state of the buzzer value:
buzzerState = digitalRead(buzzerPin);
// check if the buzzer is sounded.
// if it is, the buzzerState is HIGH:
if (buzzerState == HIGH) {
light(1);
else {
light(2);
