//declaration--
int led = 7;
//setup--
pinMode (led, OUTPUT);
//loop--
if (digitalRead(LRelayOn) == HIGH || digitalRead(HRelayOn) == HIGH) { //checks to see if either output is high
digitalWrite (led,HIGH); } //turns the LED on
else {
digitalWrite (led,LOW); } //turns the LED off
It should check to see if either of two output pins are high, and if so turn on the LED, if not turn it off.
I'm questioning the code as I am just learning, and it isn't working!
Ha! I have that same problem! And the resistors aren't getting any bigger! I like the 1/6 watters because they take up less space on PC boards, but I can't always read them without magnification or a meter.
I never bother trying to read the color bands. I'd need to compare them to a chart, which I can never find, and then interpret the values. A meter is so much easier. If you don't have one, do yourself a big favor. Put the Arduino and all the other stuff in a box. Tape it shut, and leave it alone until you get one. They are cheap. The Arduino isn't.
