I seem to be having some trouble, and I'm not sure exactly where this is occurring.
Here's my code, all I want to do is have a motor start off, and when I hit the switch turn it on. But, it's not functioning like it should.
int d1 = 15;
int m1 = 8;
int m2 = 11;
int r1 = 0;
int r1o = 0;
pinMode(d1, INPUT);
pinMode(m1, OUTPUT);
pinMode(m2, OUTPUT);
digitalWrite(m2, LOW);
r1 = digitalRead (d1);
if (r1 == LOW && r1 != r1o)
digitalWrite(m1, HIGH);
delay(50);
digitalWrite(m1, LOW);
r1o = r1;
I can't seem to get the switch to work. When I have the switch set to low, it works, but in reverse order (motor starts on, then it goes off when I hit the switch). When I switch the if to (r1 == HIGH && ... ) it works just like the LOW.
I do not have a resistor on the switch (it was doing somewhat the same thing before when it was on, and I was thinking that it was dropping the voltage too much to get the 3.3 reference).
The motor is a teeny tiny one, and it runs fine with the current in the arduino.
I would like to have the motors connected to the ground, and only use one pin to control them, but it's just not working.
Any pointers? Thanks!
