controlling a motor - variable voltage or PWM?
I'm working with this motor....
Currently I just switch it on and off using a relay, however, I'd like to start controlling it more precisely. I believe I their are two basic options.
  1. Varying the DC voltage (up and down) to increase/decrease the speed of the pump.
  2. 'Chopping' the supply to the motor using PWM.
Any recommendations please on which method to use and why?
Thanks
PWM is basically varying the voltage. A PWM dutycycle woulf give 50% of the voltage.
PWM is really just switching the motor on and off very fast - which can be equivalent to reducing the voltage.
I've worked with a PWM controlled motor many years ago, and from what I can remember the constant on-off cycling of the power caused a constant rattling vibration at the same frequency as the PWM signal, this is way I was asking about controlling the motor using a continuous voltage at a lower value, i.e. running a 12volt motor at 10, 9 or 8 volts.
Search the forum: there are some recent threads about some kind of filter on the PWM output to make it into a "real" lower voltage as opposed to the average, "pseudo" lower voltage.
Tobbera:
PWM is basically varying the voltage. A PWM dutycycle woulf give 50% of the voltage......
.... on average, but the voltage is still either all or nothing at any instant.
Wouldnt some capacitors take away the ratteling and smooth out the voltage?
Possibly but electrolytic capacitors would not last very long.
Large value film capacitors are bulky and expensive for the same values.
If your motor makes noise, increase the PWM frequency. Easier than a cap, and is usually just as effective.
http://playground.arduino.cc/Code/PwmFrequency
