Controlling a motor with a relay code
Hello,
I’m new here, so as with arduino and coding. I’m trying to move a motor with a command in the serial monitor.
I’m reading a lot about this stuff, but it’s a lot to take in. I wrote this code, i really appreciate feedback please.
int arm=2;
pinMode(arm, OUTPUT);
arm == 2;
/*pinMode default HIGH to LOW
digitalWrite(arm, LOW);
/Ask-Action/
Serial.println("Voer opdracht in… "); //Vraag
while(Serial.available()==0) {
arm = Serial.parseInt(); //Integer lezen
digitalWrite(arm, HIGH);
delay(2000);
arm == 2;Oops
Please remember to use code tags when posting code
Oh okey, thank you!
But the code won't work. I can't control the motor on command in the serial monitor. Do you have suggestions?
You're inputting a pin number, and writing HIGH to that pin number, whether or not that pin is an output.
Is that a useful summary?
Yes i tried to write a basic script for 1 motor, but i've 4 motors attached to the relay. Using more pins on a arduino MEGA 2560. I'm hoping to learn to control 1 pin, with that knowledge expand to the rest.
