Hi, I'm trying to make small device that uses an ultrasonic rangefinder and a motor to change the intensity of its vibration depending on how far away something is from the rangefinder. It uses a teensyduino and I have the rangefinder working with it and tested it by outputting a tone that changed with distance from the rangefinder, but I can't figure out how to control the intensity of the motor. If I hook it up to a pwm pin, it vibrates but the vibration doesn't change no matter what I send through the port.
Heres the code:
//#include <math.h>
int VIBRATION_PIN = 15;
int SOUNDOUT_PIN = 17;
int INPUT_PIN = 18;
double MAX_MOTOR = 255;
int VIBRATE = 0, SOUND = 1, CURRENT_MODE = 0;
double scaleFactor, inputVal;
unsigned long duration, value;
//long inputVal; //pwm value from the rangefinder
int x = 1;
long FLOOR, CEILING, DIST;
double TONE_CEILING = 400;
int count = 0, ceiling = 50;
int soundOut, vibrationOut;
void setup(){
pinMode( INPUT_PIN, INPUT);
digitalWrite( INPUT_PIN, HIGH); // turn on internal pullup, pin will be HIGH unless connected to GND by switch
scaleFactor = 0; //ratio comprised of rangefinder input value over max rangefinder value, applied to max output(audio or vibration) to get output value
//setMode( SOUND ); //just do this for now until we get vibration working
Serial.begin( 9600 );
FLOOR = 0;
CEILING = 20000;
DIST = CEILING - FLOOR;
Serial.println( "Done" );
//main loop
void loop(){
//pinMode( INPUT_PIN, INPUT );
//duration = pulseIn( INPUT_PIN, HIGH );
//duration = microsecondsToInches( duration );
//Serial.println( "16" );
// count++;
//if( count > ceiling ){
vibrationOut = 200;//= ping(); 200 IS JUST FOR TESTING PURPOSES
//count = 0;
//send feedback in appropriate mode
//if( CURRENT_MODE == SOUND){
writeVibration( vibrationOut );
unsigned long ping(){
/*pinMode( INPUT_PIN, OUTPUT );
digitalWrite( INPUT_PIN, LOW );
delayMicroseconds( 2 );
digitalWrite( INPUT_PIN, HIGH );
delayMicroseconds( 5 );
digitalWrite( INPUT_PIN, LOW );*/
//digitalWrite( INPUT_PIN, HIGH );
//calculate a ratio from the found range/max range and apply it to the max tone to calculate the tone to output
//Serial.println( duration );
//duration = 200000;
scaleFactor = ( DIST - duration );
//printDouble( scaleFactor, 100 );
double distTemp = DIST;
scaleFactor /= distTemp;
inputVal = MAX_MOTOR * scaleFactor;
//inputVal = TONE_CEILING - ( scaleFactor * TONE_CEILING );
//printDouble( inputVal, 100 );
return inputVal;
void printDouble( double val, unsigned int precision){
// prints val with number of decimal places determine by precision
// NOTE: precision is 1 followed by the number of zeros for the desired number of decimial places
// example: printDouble( 3.1415, 100); // prints 3.14 (two decimal places)
Serial.print (int(val)); //prints the int part
Serial.print("."); // print the decimal point
unsigned int frac;
if(val >= 0)
frac = (val - int(val)) * precision;
frac = (int(val)- val ) * precision;
Serial.println(frac,DEC) ;
//send tone signal
void writeTone( int freq ){
pinMode( SOUNDOUT_PIN, OUTPUT );
digitalWrite( SOUNDOUT_PIN, HIGH );
//delayMicroseconds( freq );
digitalWrite( SOUNDOUT_PIN, LOW );
void writeVibration( double intensity ){
intensity = MAX_MOTOR - intensity;
pinMode( VIBRATION_PIN, OUTPUT );
digitalWrite( VIBRATION_PIN, HIGH );
delayMicroseconds( (int)(intensity / 2) );
//digitalWrite( VIBRATION_PIN, LOW );
//delayMicroseconds( (int)(intensity / 2) );
thanks, any help would be really appreciated
-Sam
