Controlling a servo with a sound sensor
I am trying to code a servo that is controlled by a sound sensor. Essentially if it is at 180 degrees and hears the sound it should go to zero and if it is at zero degrees and hears the sound it should go to 180. I have some code but when the sound is received the servo doesn't move.
#include <Servo.h>
Servo s;
int pos = 0;
int soundpin = A2;
int threshold = 200;
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(soundpin, INPUT);
  s.attach(2);
  s.write(100);
  int sens = analogRead(soundpin);
  s.write(180);
  if(sens>=threshold && pos == 180){
    s.write(0);
    delay(15);
  }else if (sens>=threshold && pos == 0){
    s.write(180);
    delay(15);
Every time through loop() the servo is unconditionally commanded to move to 180 degrees
Why ?
Hello zachfinger
Try this:
pos
to
s.read()==180; below s.read()==0;
Awesome that solved it thank you!
Please post the working code in a new post and mark the topic solved
#include <Servo.h>
Servo s;
int pos = 0;
int soundpin = A2;
  s.attach(2);
  s.write(0);
  //s.write(180);
  if(sens>=threshold && s.read() == 180){
    s.write(0);
    delay(15);
  }else if (sens>=threshold && s.read() == 0){
    s.write(180);
    delay(15);
