I am having a problem in programming my stepper motor. I do not know how i can make the stepper motor revolve for a certain period of time or for a certain number of revolution using the Stepper.h library. Should i use a different library for this or am i missing something. thanks
Post your code!
chrisroque24:
Yes.
Your code.
And please use the code button </> so your code looks like this
and is easy to copy to a text editor
...R
Here is the code
int motor1Relay = 8;
int motor1Pin = 0; // the pin that the pushbutton is attached to
int counter = 0;
int motor1State = 0; // current state of the button
int motor1LastState = 0; // previous state of the button
volatile unsigned long coinsCount = 0; //counts coin pulses
volatile unsigned long credit = 0; // counts credit
#include <Stepper.h>
const int stepsPerRevolution = 1000;
Stepper myStepper(stepsPerRevolution, 12, 13);
void sendInfo(const __FlashStringHelper* head, char* data){
Serial.print(head);
Serial.println(data);
pinMode(motor1Pin, INPUT);
pinMode(motor1Relay, OUTPUT);
myStepper.setSpeed(120);
attachInterrupt(1, acceptorCount, RISING); //Digital interrupt pin 2
sendInfo(F("PLEASE INSERT COIN"), "");
void checkCoins(){
while (coinsCount>0){
coinsCount--;
credit = credit + 1;
Serial.print("credit : ");
Serial.println(credit);
delay(10);
checkCoins();
motor1State = digitalRead(motor1Pin);
if (motor1State != motor1LastState) {
if (motor1State == LOW && credit > 0) {
credit--;
myStepper.step(stepsPerRevolution);
digitalWrite(motor1Relay, HIGH); // turn on motor1Relay
digitalWrite(motor1Relay, LOW); // turn on motor1Relay
digitalWrite(motor1Relay, LOW); // turn off motor1Relay
delay(50);
motor1LastState = motor1State;
void acceptorCount()
coinsCount++;
Post a link to the datasheet for your stepper motor.
What stepper motor driver are you using?
If your motor driver just needs step and direction signals I suggest you use the AccelStepper library.
This Simple Stepper Code can be used for testing without any library (assuming a step/direction driver).
You have awful lot of repetition in your code. Learn about for
loops - or restructure your code to use the natural repetion of the loop()
function
...R
Stepper Motor Basics
