Controlling a Stepper with IR Remote Control
Hi Guys
I wonder if the resident genius can help me figure out what is wrong with this project. I must point out I'm very much a novice.
bit of background .. .. I've been playing with IR remote controls and built a Nano code reader to display a transmitted code when a button is pressed .. .. so I thought the next logical step was to use the code to make something happen.
I found a sketch to control a servo motor which I don't have but I do have steppers so I modified it.
However, I can't get it to work.
I've checked that the Uno is receiving the code from the remote; I've checked that the Uno will run the stepper, but I cannot get it to act upon the IR code received.
Here is my code ..
#include "Stepper.h"
#include "IRremote.h"
/*----- Variables, Pins -----*/
#define STEPS  32   // Number of steps per revolution of Internal shaft
int  Steps2Take;  // 2048 = 1 Revolution
int receiver = 3; // Signal Pin of IR receiver to Arduino Digital Pin 3
/*-----( Declare objects )-----*/
// Setup of proper sequencing for Motor Driver Pins
// In1, In2, In3, In4 in the sequence 1-3-2-4
Stepper small_stepper(STEPS, 8, 10, 9, 11);
IRrecv irrecv(receiver);    // create instance of 'irrecv'
decode_results results;     // create instance of 'decode_results'
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results)) // have we received an IR signal?
    switch (results.value)
      case 18615 : // UP button pressed  (0xFF629D)
                  small_stepper.setSpeed(500); //Max seems to be 700
                  Steps2Take  =  2048;  // Rotate CW
                  small_stepper.step(Steps2Take);
                  delay(2000);
      case 10455: // DOWN button pressed  (0xFFA857)
                  Steps2Take  =  -2048;  // Rotate CCW
                  delay(2000);
    irrecv.resume(); // receive the next value
The two codes - 18615 & 10455 are the codes identified by my code reader. The figure in brackets after the comment out is what was on the original sketch - I put that in because it appears to be a different language, which I don't understand. The Protocol is NEC.
I'd appreciate any help you can offer, I'm stumped !
Thanks
S
Hi Guys
NOTE - Please don't waste your time with this .. I've cracked it - using the wrong codes !!!
Thanks
S
