Hey guys, i have an Arduino Mega, and after running through a lot of the basics in programming the Arduino Environment and Processing, im ready to move on to Servo/Stepper controlling.
a couple of quick questions that i couldnt answer from reading:
Do i absolutely need an H-bridge to control the servos/steppers? ive seen a couple posts where they arent even mentioned, and a couple where they've been said to be necessary.
if an H-bridge isnt necessary, how can i power the servo/stepper externally?
You will need to know the type of stepper motor you have (windings/bipolar or unipolar), it's winding voltage and current ratings to actual select components and methods to drive the stepper.
you probably will burn it out. even if the current draw is small enough, when applying power to a coil of wire, you generate sharp voltage spikes which can destroy your pins. driving a motor directly off the pins is generally not recommended.
