You have "low side" switches, you need "high side" switches or relays. What is the voltage and current requirements of your valve motor? Which Arduino do you have?
With your limited background I would recommend you use two relays. Get and read the Arduino cookbook and you will be better equipped to use something else like a MOSFET>
JCA34F:
Thanks for your reply.
The valve motor requires something between 9-24V and takes at most 2 Watts, adding up to roughly 0.2 A at 12V (which i want to use) so this is quite relaxed.
I already ordered some relays, i guess this makes life way easier.
gilshultz:
Thank you for your hint! I will go for the relay solution, and get ramped up a bit more with the cookbook
Google H bridge.
Get some matching P type MOSFETS
When you find the relays are too noisy or draw too much power or fail too often you will be ready to use the H bridge.
Or buy an L298 module
