Controlling a variable pressure valve with an arduino
Hi everyone,
I'm working on a project that involves controlling a pneumatic cylinder by using an electronic pressure regulator. The regulator is controlled by a 0-5V signal, and I would like to use FSRs to control the output pressure. Does this seem feasible?
Thanks!
yes
The arduino normally does not output variable voltages, so that would be an aspect to work on. You might do a forum search for previous similar discussions.
if you are looking for help with the project, you would need to post links to the bits you want to use.
