controlling Addressable leds with HC-SR04
Hi I am trying to make this colorWipe
#include "FastLED.h"
#define NUM_LEDS 6
CRGB leds[NUM_LEDS];
#define PIN 6
FastLED.addLeds<WS2811, PIN, GRB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
// *** REPLACE FROM HERE ***
colorWipe(0x00,0xff,0x00, 50);
colorWipe(0x00,0x00,0x00, 50);
void colorWipe(byte red, byte green, byte blue, int SpeedDelay) {
for(uint16_t i=0; i<NUM_LEDS; i++) {
setPixel(i, red, green, blue);
showStrip();
delay(SpeedDelay);
// *** REPLACE TO HERE ***
void showStrip() {
#ifdef ADAFRUIT_NEOPIXEL_H
// NeoPixel
strip.show();
#endif
#ifndef ADAFRUIT_NEOPIXEL_H
// FastLED
FastLED.show();
#endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
// NeoPixel
strip.setPixelColor(Pixel, strip.Color(red, green, blue));
#endif
// FastLED
leds[Pixel].r = red;
leds[Pixel].g = green;
leds[Pixel].b = blue;
#endif
void setAll(byte red, byte green, byte blue) {
for(int i = 0; i < NUM_LEDS; i++ ) {
showStrip();
go faster the closer i am to the Hc-SR04 I have the colorWipe sketch working and I have this sketch for the HC-SR04
// Turning NeoPixels on and off using a HC-SRO4 Ping Sensor
This sketch reads a HC-SR04 ultrasonic rangefinder and returns the
distance to the closest object in range. To do this, it sends a pulse
to the sensor to initiate a reading, then listens for a pulse
to return. The length of the returning pulse is proportional to
the distance of the object from the sensor.
The Arduino then takes this information and illuminates a strip of
NeoPixel's based on the distance of the object from the sensor.
This code was developed partially from Ping))) code found in the public domain
written by David A. Mellis, and adapted to the HC-SRO4 by Tautvidas Sipavicius,
while other portions were written by Charles Gantt and Curtis Gauger from
http://www.themakersworkbench.com.
//Tell the Arduino IDE to include the FastLED library
#include <FastLED.h>
//Setup the variables for the HC-SR04
const int trigPin = 8;
const int echoPin = 7;
//Setup the variables for the NeoPixel Strip
#define NUM_LEDS 7 // How many leds in your strip?
#define DATA_PIN 6 // What pin is the NeoPixel's data line connected to?
CRGB leds[NUM_LEDS]; // Define the array of leds
// initialize serial communication:
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, inches, cm;
// The sensor is triggered by a HIGH pulse of 10 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Read the signal from the sensor: a HIGH pulse whose
// duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
if (cm <= 40) {fill_solid( &(leds[0]), NUM_LEDS /number of leds/, CRGB::Green); //{whitestrobe(30);
FastLED.show();
else if (cm >= 41) {fill_solid( &(leds[0]), NUM_LEDS /number of leds/, CRGB::Black);
FastLED.show();
delay(100);
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
how can I combine the tow?
      showStrip();
      delay(SpeedDelay);
The speed of the colour wipe depends on the value of SpeedDelay passed to the function. You could make that value dependant on the distance returned by the sensor. However, as written the speed will only change once the colour wipe is finished. Is that acceptable ?
thanks for the fast reply yes that should work I think sorry for the noob question but how would i make the speedDelay dependent on distance?
What range of distances do you want to react to ?
From 300cm getting faster as I get closer
From 300cm to 20cm getting faster as I get closer
OK. The simple but clumsy way to do this is to use discrete speed bands. For instance if you wanted 3 bands then you could do something like
if (distance < 100)
  SpeedDelay = 50;
if (distance < 200)
  SpeedDelay = 100;
if (distance < 300)
  SpeedDelay = 200;
Adjust the values and number of bands to suit your requirements
A smarter way would be to use the map() function to derive a speed delay proportional to the distance. Something like
SpeedDelay = map(distance, 0, 300, 100, 300);  //input 0 to 100, output 100 to 300
thanks I now have this // Turning NeoPixels on and off using a HC-SRO4 Ping Sensor
#define PIN 6 // What pin is the NeoPixel's data line connected to?
Serial.print(cm);
Serial.print("cm");
void colorWipe(byte red, byte green, byte blue, int SpeedDelay=map(distance, 0, 300, 100, 300); }
showStrip();
0
void showStrip() {
// NeoPixel
strip.show();
#endif
// FastLED
FastLED.show();
#endif
// NeoPixel
#endif
// FastLED
#endif
showStrip();
but am getting colorWipe was not declared in this scope
Check the colorWipe() function definition
Here is the start of it
void colorWipe(byte red, byte green, byte blue, int SpeedDelay = map(distance, 0, 300, 100, 300);
for (uint16_t i = 0; i < NUM_LEDS; i++)
Does it look like the start of any other function definition ?
yes colorWipe(0x00,0xff,0x00, 50);
do I not need that any more? if I remove it I get distance was not declared in this scope
sorry for the noob questions I know I am probable missing something really simple
I have moved void colorWipe(byte red, byte green, byte blue, int SpeedDelay = map(distance, 0, 300, 100, 300); {
showStrip();
delay(SpeedDelay);
above
colorWipe(0x00, 0xff, 0x00, 300);
colorWipe(0x00, 0x00, 0x00, 300);
and now get distance was not declared in this scope
Try this.
Leave the colorWipe() function as it is, ie
    showStrip();
    delay(SpeedDelay);
Work out the required delay like this, substituting your own variable name for distance
int mappedDelay = map(distance, 0, 300, 100, 300);  //input 0 to 100, output 100 to 300
Then call the colorWipe() function like this
colorWipe(0x00,0xff,0x00, mappedDelay);
I can't try it because I don't have the same hardware as you
I frankencoded an arduino sketch to display distance data on LCD and play different sounds based on a distance scanner (happens to be a TFMini) but similar circumstances...may be of interest to you....
build details here:
code details here:
https://forums.adafruit.com/viewtopic.php?f=25&t=142445&p=710141#p710141
Thank you very much for all your help I now have a working sketch
// defines pins numbers
#define LED_PIN 6
#define NUM_LEDS 6
#define BRIGHTNESS 64
#define LED_TYPE WS2811
#define COLOR_ORDER GRB
#define UPDATES_PER_SECOND 100
// defines variables
long duration;
int distance;
delay( 3000 ); // power-up safety delay
FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( BRIGHTNESS );
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
Serial.begin(115200); // Starts the serial communication
// Clears the trigPin
// Sets the trigPin on HIGH state for 10 micro seconds
// Reads the echoPin, returns the sound wave travel time in microseconds
// Calculating the distance
distance= duration*0.034/2;
// Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
colorWipe(0x00,0x00,0x00, mappedDelay);
showStrip();
delay(SpeedDelay);
// ---> here we define the effect function <---
void showStrip() {
// NeoPixel
strip.show();
#endif
// FastLED
FastLED.show();
#endif
// NeoPixel
#endif
// FastLED
#endif
showStrip();
That's good news, but you have not learned to Auto Format the code in the IDE and use code tags like this when posting here to make it easier to read and copy to an editor
#define LED_PIN     6
#define NUM_LEDS    6
long duration;
int distance;
  distance = duration * 0.034 / 2;
  colorWipe(0x00, 0xff, 0x00, mappedDelay);
  colorWipe(0x00, 0x00, 0x00, mappedDelay);
    showStrip();
    delay(SpeedDelay);
void showStrip()
  // NeoPixel
  strip.show();
#endif
  // FastLED
  FastLED.show();
#endif
  // NeoPixel
#endif
  // FastLED
#endif
  for (int i = 0; i < NUM_LEDS; i++ )
  showStrip();
Thanks
