Controlling an Analog Valve using Arduino
I want to control an air flow using valve and arduino. I need suggestions and code regarding what kind of valve can be used and codes for the same. I tried finding information for the motorized ball valve, but couldn't get it.
...and you may wish to move this topic to a more appropriate forum section
For useful suggestions, provide a better description of the project than "control air flow". Volume, pressure, size of conduits, etc.
This is not an "introductory tutorial", so use the flag button to ask a moderator to move your post.
@spd17, your topic has been moved to a more suitable location on the forum. Introductory Tutorials is for tutorials that e.g. you write, not for questions. Feel free to write a tutorial once you have solved your problem :wink:
Look at a few valves with Mr Google , find some that look as though they can do the job ( size , pressure etc etc ) , then think if you could control them or ask here .
There are a lot of options out there !
There is a great difference between a valve to control low pressure air flow from a fan or blower through large ducts and a valve that controls flow rate of high pressure, compressed air through small pipes and tubing (pneumatic fluid power). Please describe your project in detail.
