Controlling an esc with PCF8574
Hi, i am fairly new to arduino and i'am building a quadcopter with it. It has been a very educational project and i am coming to an end to see my quad flying.
But i've ran into a problem that i am running out of digital pins (analogs are also in use). And i still have 4 esc's to drive.
But luckily i have 2 PCF8574's lying around and esc's are expecting a pwm signal from 1000µs to 2000µs.
I've tried the code as follows but no luck, the three of the esc's are geting around a ~1300µs pulse (don't have an oscilloscope just guessing by motor speed) and one of them doesn't get any signal at all
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include <Wire.h>
#include "PCF8574.h"
#define PCF8574_ADDRESS 0x20
PCF8574 pcf20(PCF8574_ADDRESS);
RF24 radio(9, 10);
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
int throttle = 1000;
  Wire.begin();
  pcf20.begin();
  pcf20.write8(LOW);
  Serial.begin(57600);
  radio.begin();
  radio.setRetries(15, 15);
  radio.setAutoAck(false);
  radio.setDataRate(RF24_250KBPS);
  radio.openReadingPipe(1, pipes[1]);
  radio.startListening();
  while ( radio.available() ) {
    radio.read(&throttle, sizeof(int));
  Serial.println(throttle);
  pcf20.toggle(0); // P0 high
  delayMicroseconds(throttle);
  pcf20.toggle(0); // P0 low
  delay(2);
  pcf20.toggle(1); // P1 high
  pcf20.toggle(1); // P1 low
  delay(2);
  pcf20.toggle(2); // P2 high
  pcf20.toggle(2); // P2 low
  delay(2);
  pcf20.toggle(3); // P3 high
  pcf20.toggle(3); // P3 low
  delay(2);
  //This works fine with digital pins
  digitalWrite(pwmPin1, HIGH);
  digitalWrite(pwmPin1, LOW);
  delay(2);
  digitalWrite(pwmPin2, HIGH);
  digitalWrite(pwmPin2, LOW);
  delay(2);
  digitalWrite(pwmPin3, HIGH);
  digitalWrite(pwmPin3, LOW);
  delay(2);
  digitalWrite(pwmPin4, HIGH);
  digitalWrite(pwmPin4, LOW);
  delay(2);
My question is can you generate a pwm signal with PCF8574?
(Using an arduino uno).
Thanks in advance
You /could/ do it, but it would mean that you needed to write to the PCF8574 CONSTANTLY and the Arduino wouldn't have time to do much more else.
You need something like this: Adafruit 16-Channel 12-bit PWM/Servo Shield - I2C interface : ID 1411 : $17.50 : Adafruit Industries, Unique & fun DIY electronics and kits
The chip on the board is actually a LED-driver, but the clever part is that it's PWM-frequency can be set, so it emulates a "servo"-signal (what your ESC needs) and you can control the duty cycle by writing to the registers of it.
// Per.
Thank you zapro for your answer. after some research i also realized it was kinda hard and went on bought another arduino uno. Thanks again for your time.
