here is the full code
Code Name: Arduino Bluetooth Car with Front and Back Light Control
Code URI: Arduino Projects Archives - CircuitBest
Before uploading the code you have to install the "Adafruit Motor Shield" library
Open Arduino IDE >> Go to sketch >> Include Libray >> Manage Librays... >> Search "Adafruit Motor Shield" >> Install the Library
AFMotor Library: Library Install | Adafruit Motor Shield | Adafruit Learning System
Author: Make DIY
Author URI: admin, Author at CircuitBest
Description: This program is used to control a robot using an app that communicates with Arduino through an HC-05 Bluetooth Module.
App URI: Bluetooth Car Make DIY.apk - Google Drive
Version: 1.0
License: Remixing or Changing this Thing is allowed. Commercial use is not allowed.
#include <AFMotor.h>
#include <Wire.h>
#include <MPU6050_light.h>
MPU6050 mpu(Wire);
unsigned long timer = 0;
float radius_of_wheel = 0.033; //Measure the radius of your wheel and enter it here in cm
//initial motors pin
AF_DCMotor motor1(1, MOTOR12_8KHZ);
AF_DCMotor motor2(2, MOTOR12_8KHZ);
AF_DCMotor motor3(3, MOTOR34_8KHZ);
AF_DCMotor motor4(4, MOTOR34_8KHZ);
int val;
int Speeed = 110;
int left_intr = 0;
/boolean conditions/
boolean one = true;
boolean two = true;
boolean three = true;
/Hardware details/
int x;
int y;
int z;
int Y;
/* falues of boolean as 1 and 0 in integer formart*/
int w = 0;
int q = 0;
int e = 0;
int r = 0;
int l = 0;
int p = 0;
int u = 0;
//int pp;
/distance value/
int d;
volatile byte rotation; // variale for interrupt fun must be volatile
float timetaken, rpm, dtime;
float v;
int distance;
unsigned long pevtime;
float rev;
Serial.begin(9600); //Set the baud rate to your Bluetooth module.
rotation = rpm = pevtime = 0; //Initialize all variable to zero
// mpu setting
Wire.begin();
byte status = mpu.begin();
Serial.print(F("MPU6050 status: "));
Serial.println(status);
while (status != 0) { } // stop everything if could not connect to MPU6050
Serial.println(F("Calculating offsets, do not move MPU6050"));
// mpu.upsideDownMounting = true; // uncomment this line if the MPU6050 is mounted upside-down
mpu.calcOffsets(); // gyro and accelero
Serial.println("Done!\n");
void Left_ISR()
left_intr++; delay(10);
rotation++;
dtime = millis();
if (rotation >= 40)
timetaken = millis() - pevtime; //timetaken in millisec
rpm = (1000 / timetaken) * 60; //formulae to calculate rpm
pevtime = millis();
rotation = 0;
// read mpu
mpu.update();
if ((millis() - timer) > 100) { // print data every 10ms
Serial.print("X : ");
Serial.print(x);
Serial.print("\tY : ");
Serial.print(y);
Serial.print("\tZ : ");
Serial.println(z);
x = round(mpu.getAngleX());
y = round(mpu.getAngleY());
z = round(mpu.getAngleZ());
//Serial.print("X : ");
// Serial.print(x);
// Serial.print("\tY : ");
// Serial.print(y);
// Serial.print("\tZ : ");
// Serial.println(z);
timer = millis();
/positive is anticlockwie ...negative clockwise/ foward one/
if (w == 0) {
if (z == 0) {
left();
else if ((z > 0) && (z <= 4)) {
//delay(200);
left();
else if ((z >= 4) && (z <= 9)) {
//Stop();
//delay(100);
forward1();
/*distance condition*/
//set bolean to false/true
// /* move z axis right/ foward 2*/
if (p == 1) {
//Stop();
/edit values of z/
if (z > 0) {
right();
} else if (z < 0) {
//Stop();
Y = abs(z) /+ 1000/;
Serial.println(Y);
if ((Y > 57) && (y < 60)) {
//Serial.print("y is greater than 1030");
//left_intr=0;
forward2();
} else if (y < 55) {
right();
/move z axis second right foward 3/
if (e == 1) {
/edit values of z / as z is in negative direction convert to positive/
if (z < 0) {
//Stop();
Y = abs(z) /*+ 1000*/;
Serial.println(Y);
if ((Y > 140) && (y < 144)) {
forward3();
} else if (y < 140) {
right();
/move z axis second right foward 4/
if (r == 1) {
if (z < 0) {
//Stop();
Serial.println(Y);
if ((Y > 210) && (y < 214)) {
forward4();
} else if (y < 210) {
right();
}else if (y > 250) {
left();
if (u == 1) {
if (z < 0) {
Stop();
Serial.println(Y);
// if ((Y > 200) && (y < 210)) {
// //Serial.print("y is greater than 1030");
// forward4();
// } else if (y < 200) {
// right();
void forward1()
//one=false;
motor1.setSpeed(Speeed); //Define maximum velocity
motor1.run(FORWARD); //rotate the motor clockwise
motor2.setSpeed(Speeed); //Define maximum velocity
motor2.run(FORWARD); //rotate the motor clockwise
motor3.setSpeed(Speeed);//Define maximum velocity
motor3.run(FORWARD); //rotate the motor clockwise
motor4.setSpeed(Speeed);//Define maximum velocity
motor4.run(FORWARD); //rotate the motor clockwise
attachInterrupt(digitalPinToInterrupt(2), Left_ISR, CHANGE); //Left_ISR is called when left wheel sensor is triggered
v = radius_of_wheel * rpm * 0.104; //0.033 is the radius of the wheel in meter
distance = (2 * 3.141 * radius_of_wheel) * (left_intr / 40);
Serial.print("rotation"); Serial.print(left_intr);
Serial.print("v"); Serial.print(v);
Serial.print("d"); Serial.print(distance); Serial.println("");
//d=4;
//delay(20000);
if (distance == 1) {
//Serial.println("distance is 4:");
//delay(500);
//l = 1;
e = 0;
w = 1;
p = 1;
r = 0;
u = 0;
detachInterrupt(2);
//Stop();
//noInterrupts();
//interrupts();
void forward2()
//one=false;
// interrupts(); //Left_ISR is called when left wheel sensor is triggered
delay(2000);
e = 1;
p = 0;
//Stop();
// if (distance == 5) {
// Serial.println("distance is 4:");
// //l = z;
// e = 1;
// p = 0;
// Stop();
void forward3()
//one=false;
delay(2000);
r = 1;
e= 0;
void forward4()
//one=false;
delay(2000);
r=0;
u=1;
void forward5()
//one=false;
delay(2000);
e = 0;
w = 1;
p = 0;
r = 0;
u = 1;
void back()
left_intr = 0;
motor1.run(BACKWARD); //rotate the motor anti-clockwise
motor2.run(BACKWARD); //rotate the motor anti-clockwise
motor3.setSpeed(Speeed); //Define maximum velocity
motor3.run(BACKWARD); //rotate the motor anti-clockwise
motor4.setSpeed(Speeed); //Define maximum velocity
motor4.run(BACKWARD); //rotate the motor anti-clockwise
void left()
left_intr = 0;
void right()
void topleft() {
left_intr = 0;
motor3.setSpeed(Speeed / 3.1); //Define maximum velocity
motor4.setSpeed(Speeed / 3.1); //Define maximum velocity
void topright()
left_intr = 0;
motor1.setSpeed(Speeed / 3.1); //Define maximum velocity
motor2.setSpeed(Speeed / 3.1); //Define maximum velocity
void bottomleft()
left_intr = 0;
void bottomright()
left_intr = 0;
void Stop()
motor1.setSpeed(0); //Define minimum velocity
motor1.run(RELEASE); //stop the motor when release the button
motor2.setSpeed(0); //Define minimum velocity
motor2.run(RELEASE); //rotate the motor clockwise
motor3.setSpeed(0); //Define minimum velocity
motor3.run(RELEASE); //stop the motor when release the button
motor4.setSpeed(0); //Define minimum velocity
motor4.run(RELEASE); //stop the motor when release the button
