Controlling Arduino Due with Node Red on Pi4
Hey everyone,
I'm working on a project where I'd like to control an Arduino Due with a touch screen on a Pi4. I'm using Node Red as the UI on the Pi and Standard Fermata for the Arduino. For now, I'm just trying to read a digital pin on the due, which is controlled by a Node Red flow, and print a message to an LCD screen (just to test communication). It appears that the natural state of digital pins 31-34 (the pins I'm using) is high as the LCD screen is printing "1" as the digitalRead on the pins. I've been able to get a flow working with a switch node and a stepper motor, but for some reason when I change to a button node, it stops working. Connections are all fine. I'm not sure if the problem is on the Arduino side or the NodeRed side. I wish I could be more specific, but I'm not entirely sure where I'm going wrong.
The entire sketch for Standard Fermata is too long to post but I made some simple changes to the setup and loop and added a few simple functions.
void printScare(){
  lcd.print("Scaring");
void printFight(){
  lcd.print("Fighting");
void printRest(){
  lcd.print("Resting");
void printConfuse(){
  lcd.print("Confusing");
  systemResetCallback();
  pinMode(31, INPUT);
  pinMode(32, INPUT);
  pinMode(33, INPUT);
  pinMode(34, INPUT);
  Wire.begin();
  //Serial.begin(9600);
  Serial.println("\nI2C Scanner");
  lcd._Addr = iicScanner();
  lcd.init();
  lcd.backlight();
  lcd.print("IN SETUP");
  Firmata.setFirmwareVersion(FIRMATA_FIRMWARE_MAJOR_VERSION, FIRMATA_FIRMWARE_MINOR_VERSION);
  Firmata.attach(ANALOG_MESSAGE, analogWriteCallback);
  Firmata.attach(DIGITAL_MESSAGE, digitalWriteCallback);
  Firmata.attach(REPORT_ANALOG, reportAnalogCallback);
  Firmata.attach(REPORT_DIGITAL, reportDigitalCallback);
  Firmata.attach(SET_PIN_MODE, setPinModeCallback);
  Firmata.attach(SET_DIGITAL_PIN_VALUE, setPinValueCallback);
  Firmata.attach(START_SYSEX, sysexCallback);
  Firmata.attach(SYSTEM_RESET, systemResetCallback);
  // to use a port other than Serial, such as Serial1 on an Arduino Leonardo or Mega,
  // Call begin(baud) on the alternate serial port and pass it to Firmata to begin like this:
  Serial1.begin(57600);
  Firmata.begin(Serial1);
  // However do not do this if you are using SERIAL_MESSAGE
  Firmata.begin(57600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for ATmega32u4-based boards and Arduino 101
  lcd.clear();
 * LOOP()
void loop(){
  //lcd.print("IN LOOP");
  lcd.clear();
  if(digitalRead(31) == LOW){
    printScare();
  if(digitalRead(32) == LOW){
    printFight();
  if(digitalRead(33) == LOW){
    printRest();
  if(digitalRead(34) == LOW){
    printConfuse();
  byte pin, analogPin;
  /* DIGITALREAD - as fast as possible, check for changes and output them to the
   * FTDI buffer using Serial.print()  */
  //checkDigitalInputs();
  /* STREAMREAD - processing incoming messagse as soon as possible, while still
   * checking digital inputs.  */
  while (Firmata.available())
    Firmata.processInput();
  // TODO - ensure that Stream buffer doesn't go over 60 bytes
  currentMillis = millis();
  if (currentMillis - previousMillis > samplingInterval) {
    previousMillis += samplingInterval;
    /* ANALOGREAD - do all analogReads() at the configured sampling interval */
    for (pin = 0; pin < TOTAL_PINS; pin++) {
      if (IS_PIN_ANALOG(pin) && Firmata.getPinMode(pin) == PIN_MODE_ANALOG) {
        analogPin = PIN_TO_ANALOG(pin);
        if (analogInputsToReport & (1 << analogPin)) {
          Firmata.sendAnalog(analogPin, analogRead(analogPin));
    // report i2c data for all device with read continuous mode enabled
    if (queryIndex > -1) {
      for (byte i = 0; i < queryIndex + 1; i++) {
        readAndReportData(query[i].addr, query[i].reg, query[i].bytes, query[i].stopTX);
#ifdef FIRMATA_SERIAL_FEATURE
  serialFeature.update();
#endif
I'm still new to Node Red, so any help I could get there as well would be fantastic!
Thanks so much!
