Hi Guys,
As it says in the title, I want to try to control an Arduino Mega with an Android phone, to start off with I just want to control an LED with my Android by sending a simple 1. So, basically what I have done so far is that I have managed to connect my Arduino to the Arduino Mega which has a USB Shield and I can send digits/messages to and from the phone terminal App and the PC Arduino Serial Monitor. I have tried to play around with the code but I honestly cant figure it out after many attempts, here's the code for sending messages from the phone to computer and vice versa:
#include <SPP.h>
#include <usbhub.h>
// Satisfy IDE, which only needs to see the include statment in the ino.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#include <SPI.h>
#endif
USB Usb;
//USBHub Hub1(&Usb); // Some dongles have a hub inside
BTD Btd(&Usb); // You have to create the Bluetooth Dongle instance like so
/* You can create the instance of the class in two ways */
SPP SerialBT(&Btd); // This will set the name to the defaults: "Arduino" and the pin to "0000"
//SPP SerialBT(&Btd, "Lauszus's Arduino", "1234"); // You can also set the name and pin like so
bool firstMessage = true;
#if !defined(__MIPSEL__)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start"));
while (1); //halt
Serial.print(F("\r\nSPP Bluetooth Library Started"));
Usb.Task(); // The SPP data is actually not send until this is called, one could call SerialBT.send() directly as well
if (SerialBT.connected) {
if (firstMessage) {
firstMessage = false;
SerialBT.println(F("Hello from Arduino")); // Send welcome message
if (Serial.available())
SerialBT.write(Serial.read());
if (SerialBT.available())
Serial.write(SerialBT.read());
Any help at all will be greatly appreciated.
One of the things I tried was:
if(SerialBT.read() == '1');
digitalWrite(9, HIGH);
but it didn't work :S
