Controlling arduino outputs through html webpage stored on SD card
Can someone help me out with this problem:
My problem: I have an htm file in the sd card and i just want it to turn on/off my digital outputs I 'll put the arduino source code and the htm file.
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
String readString = String(100); //string for fetching data from address
    // disable Ethernet chip
    pinMode(10, OUTPUT);
    digitalWrite(10, HIGH);
    Serial.begin(9600);       // for debugging
    // initialize SD card
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - SD card initialization failed!");
        return;    // init failed
    Serial.println("SUCCESS - SD card initialized.");
    // check for index.htm file
    if (!SD.exists("index.htm")) {
        Serial.println("ERROR - Can't find index.htm file!");
        return;  // can't find index file
    Serial.println("SUCCESS - Found index.htm file.");
    // LEDs
  pinMode(6, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  // start the Ethernet connection and the server:
  Serial.println(F("Initiaizing ethernet..."));
  // this uses a fixed address
  Ethernet.begin(mac, ip);
  // get an address with DHCP
  //if (Ethernet.begin(mac) == 0)
  //  Serial.println("Failed to configure Ethernet using DHCP");
  // give the card a second to initialize
  server.begin();
  Serial.print(F("Garage Door Opener Control Ready at IP address "));
  Serial.println(Ethernet.localIP());
  // command received (one character)  '1' - activate garage door button
  char cmd = 0;          // 1 - pulse button
  boolean done = false;  // set to indicate that response is complete
  // listen for incoming clients
  if (client) {
    Serial.println(F("new client"));
    readString = "";
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        //int i = c;
        //Serial.print("(");
        //Serial.print(i);
        //Serial.print(")");
        // store character received in receive string
        if (readString.length() < 100) {
          readString += (c);
        // check for end of line
        if (c == '\n') {
            //Serial.print("Receved line: ");
            //Serial.print(readString);
            // process line if its the "GET" request
            // a request looks like "GET /?1" or "GET /?2"
            if (readString.indexOf("GET") != -1) {
                if (readString.indexOf("?1") != -1)
                   cmd = '1';
                // check for other commands here. ie turn on light, etc.
                if (readString.indexOf("?2") != -1)
                   cmd = '2';
                                  if (readString.indexOf("?3") != -1)
                   cmd = '3';
                                  if (readString.indexOf("?4") != -1)
                   cmd = '4';
                                  if (readString.indexOf("?5") != -1)
                   cmd = '5';
                                  if (readString.indexOf("?6") != -1)
                   cmd = '6';
                                  if (readString.indexOf("?7") != -1)
                   cmd = '7';
                                 if (readString.indexOf("?8") != -1)
                   cmd = '8';
           // if a blank line was received (just cr lf, length of 2), then its the end of the request
           if (readString.length() == 2) {
             if (cmd == '1'){
                Serial.println(F("Activate Button"));
                digitalWrite(6, HIGH);
                          if (cmd == '2'){
                digitalWrite(6, LOW);
                          if (cmd == '3'){
                digitalWrite(5, HIGH);
                          if (cmd == '4'){
                digitalWrite(5, LOW);
                          if (cmd == '5'){
                digitalWrite(7, HIGH);
                          if (cmd == '6'){
                digitalWrite(7, LOW);
                          if (cmd == '7'){
                digitalWrite(8, HIGH);
                          if (cmd == '8'){
                digitalWrite(8, LOW);
             // add other commands here
             // send web page back to client
             Serial.println(F("sending web page"));
             SendWebPage(client);
             Serial.println(F("web page sent"));
             cmd = 0;
             // break out and disconnect. This will tell the browser the request is complete without having to specify content-length
           }  // end of request reached
           // start line over
           readString = "";
        }  // end of line reached
      }  // end data is available from client
    }  // end cient is connected
    // give the web browser time to receive the data
    Serial.println(F("delay before disconnect"));
    delay(100);
    // close the connection:
    client.stop();
    Serial.println(F("client disonnected"));
  }  // end client has been created
// send web page
static File SDFile;
void SendWebPage(EthernetClient client) {
   byte buff[32]; // The sending buffer; its size (now 32) influences directly RAM-Usage
   SDFile = SD.open("index.htm", FILE_READ); // Open the file index.htm on the root of your SDCard
   if (SDFile) {
      while(SDFile.available()) { // Is there still data to be read in the file
          memset(buff, '\n', sizeof(buff)); // Reset the buffer
          SDFile.read(buff, sizeof(buff)); // Read the next chunk of data to the buffer
          client.write(buff, sizeof(buff)); // Send the just read chunk of data to the client
      Serial.println("SDFile Read Error");
this is the htm file, but it does not switch on the digital outputs of the arduino, can you tell me what am i supposed to do? this post is my last and final problem
<!DOCTYPE HTML>
<html>
<head>
<title>Home Automation Control</title>
<style type='text/css'>
.label {font-size: 30px; text-align:center;}
button {width: 160px; height: 70px; font-size: 30px; -webkit-appearance: none; background-color:#dfe3ee; }
</style>
<script type='text/javascript'>
function OnButtonClicked(parm) { window.location.href=\"X?\" + parm; }
</script>
</head>
<body style=\"background-color:#3b5998\">
<div class=\"label\">
Home Auotmation Control
<button onclick=\"OnButtonClicked('1');\">1ON</button>
<button onclick=\"OnButtonClicked('2');\">1Off</button>
<button onclick=\"OnButtonClicked('3');\">2ON</button>
<button onclick=\"OnButtonClicked('4');\">2Off</button>
<button onclick=\"OnButtonClicked('5');\">3ON</button>
<button onclick=\"OnButtonClicked('6');\">3Off</button>
<button onclick=\"OnButtonClicked('7');\">4ON</button>
<button onclick=\"OnButtonClicked('8');\">4Off</button>
</div>
</body>
</html>
I hate to have to say it.... but I must admit, if I am guessing correctly from your thread title what you want to do... a Pi might be just the thing!
Just swap the SD card in the hardware, and it is a "new system", now doing whatever is in the new SD card, without any other "set up" hassle.
tkbyd: I hate to have to say it.... but I must admit, if I am guessing correctly from your thread title what you want to do... a Pi might be just the thing!
Hey, thanks for the reply!
I 'll check out the PI but i didnt understand by what u mean in this sentence"Just swap the SD card in the hardware, and it is a "new system", now doing whatever is in the new SD card, without any other "set up" hassle."
Could you please explain? Thanks a lot
