I am running a simple Hello World program to display it in 16*2 LCD. The backlight of LCD is so much dark that Hello world is not visible. Any option to control the backlight without using potentiometer. Sample code is attached below.
#include <LiquidCrystal.h>
int Contrast=100;
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
analogWrite(A0,Contrast);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
Treat the backlight as an LED, which is what it is and control the brightness with a PWM signal. If the backlight draws over 30mA then use a transistor to drive it. You need a seriese resistor in the backlight led to limit the current to a safe value. There may already be resistors on the LCD in seriese with the backlight.
Contrast and backlight brightness are 2 different things, contrast is usually a 1 time adjustment with the potentiometer on the back, some backlights can be adjusted with PWM, some with code, some are not adjustable, only ON or OFF.
ashishpandey:
It is probable that you are referring to the contrast adjustment, nothing to do with the backlight.
