We have a flexible roof on our terrace with blinds on each side I would like to embed in our Fibaro Home Center.
The controller and remote are from Teleco - since Teleco offers a RS232 module (https://www.telecoautomation.com/de/scheda_prodotto/tvtrx232/) for home automation I ordered it right away assuming it should be easy to control it via an Arduino.
Specs of the module: https://manuals.plus/m/dded6aec2ec2d56f28eeb17e070109312d2e7165f1561dd2dc8bcae845c19c58_optim.pdf
The TVTRX232 module works just fine using my macbook, a random usb2rs232 converter (Amazon: B01LVYR1AB) and Serial (Decisivetactics).
However it doesn't react at all when trying to send the same hex-code from my Arduino - meanwhile tested two different Arduinos as well as two different TTL converters (1: Amazon: B07ZDK4BLH 2: Conrad: 1310314 ).
I've tried both via the hardware serial as well as using SoftwareSerial.h - same no-result. Also tried multiple approaches on how to send it:
#include <SoftwareSerial.h>
int RX_PIN = 2;
int TX_PIN = 3;
const byte DataStream[] =
0x54, 0x01, 0x2F, 0x00, 0x01, 0x85,
const int DataStreamLength = sizeof DataStream;
unsigned long previousMillis = 0;
const long interval = 5000;
const int ledPin = LED_BUILTIN;
Serial.begin(19200);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial1.begin(19200);
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
pinMode(ledPin, HIGH);
delay(2000);
Serial.write(DataStream, DataStreamLength);
//Serial1.write(DataStream, DataStreamLength);
delay(2000);
Serial.write("0x54012F000185");
//Serial.write("0x54012F000185");
delay(2000);
Serial.write(0x54);
Serial.write(0x01);
Serial.write(0x2F);
Serial.write(0x00);
Serial.write(0x01);
Serial.write(0x85);
delay(2000);
pinMode(ledPin, LOW);
I must be missing something - if I connect the Arduino to the mac it seems to send it just fine, however the module does not respond at all - no commands are being sent to the blinds, no response back via rs232 (not even an error).
Any ideas?
Thanks
Michael
PS: sorry I would have put the amazon links, but it was allowing only two links ![]()
