Controlling brightness for a DC incandescent light
Hello all,
first post, and possible dumb question. :slight_smile:
I am looking to control, via Arduino, The brightness of a DC incandescent light bulb (12v-24v). Like the type you would find in a typical hand held flashlight (torch).
Now I have played with the PWM dimming samples and LEDs, but I would need something additional for an incandescent light as it requires more power, right?
I searched the forum, and found dimming applications for AC, but I am thinking this has got to be much simpler. I imagine it would involve adding more resistance in series with the bulb or controlling the voltage across the bulb leads?
Any suggestions?
thanks!
-rob
To control an incandescent bulb, you need to use a transistor; look at the examples in the playground and elsewhere for controlling a relay or solenoid. The only difference would be that you don't need the diode across the load (in a relay or solenoid, the coil - in your case, the lamp), because there is no inductive kickback.
Then, drive the transistor with your PWM signal as normal...
Great, thanks for the tip.
BTW, I am looking into these opto-isolated solid state DC relays for another switching application.
http://www.opto22.com/site/pr_details.aspx?cid=4&item=DC60MP
Could these also be used be used for dimming the DC light as well (by driving it with PWM)??
I know this would not work well with a mechanical relay (not fast enough). But I am not that familiar with these relays.
thanks
